Side wall bulge
These tyres had done just 3000 km and haven't crashed into any pothole or clipped the curb.
The make are pirelli p zero 245/35 R19 front and 275/30 back.
Got the tyre checked at the dealership there wasnt any crack on the inner wall.
They said they'll follow a procedure where they will send the images to pirelli and wait for their response if it will get covered in warranty.
Can i claim that this is a manufacturing defect as there are no signs of impact on the tyre,no cracks on the inner wall?W
hat are the chances it will be accepted as a warranty claim?
Most bulges are caused by impact damage and there will be few external signs other than the bulge. The extent of damage can only be confirmed by x-ray.
A bulge is a sign that the internal belts are damaged. Such damage can only really be caused by impact.
I always keep my tyre covered with shiner
.and it was all black when they took the photo
Same with most Conti tires that come with the car.
I had a tire on my Dodge pickup that had four "bubbles" on it. This was a Michelin tire and I know for 100% sure the tire was never run over a pot hole. Just a very bad tire quality from these "premium" tire makers.
With my current car I have driven over many potholes bad enough to bend my 18" stock rims but no "bubbles" on tires. Went to soften the ride and got 17" rims but this does not lessen the amount of the pot holes. No "bubbles" on tires with these either and these have seen very bad ones.
But I don't run on Michelins, Pirtellis or Contis either. Did have Firestones once but their rubber plain cracked on the inside wall. Outside did not as it sees car washes with shines and I was lucky I did not have a blow-out. No more Firestones for me!
"Bubbles" on tires always is a tire quality issue and it is the tire maker's excuse to blame that you hit a pot hole. A tire is supposed to handle the pot hole unless the impact is so bad it breaks the rim.
I live in Chicago where all roads suck and I always check after hitting a big pothole which are unavoidable. I have had multiple bent rims as well and I can see below the bubble on the rim where the impact occurred. It is always a smear of rubber at the edge of the rim. Maybe I have been driving on the wrong tires all of these years.
I have been running the same continentals that came on the car when I bought it. Never had a problem. But then asking for opinions on tires is like asking for opinions on women. Challenge the dealer who sold you the tires.
Each pothole is different and in some cities there are more potholes that smooth surfaces. A tire cannot be expected to handle everything. There are just too many variables - speed, depth, how you hit the pothole, outside temperature, temperature of tire, inflation and so forth.
Clearly, lower profile tires are more susceptible to impact damage and a bubble is merely a visible sign of belt separation.
Some tires (like the Goodyear LS fitted to BMW 535 with the 19" tires) are just more likely to suffer impact damage but the damage is ALWAYS caused by impact damage.
As the stock wheels were hideous to me and didn't suit the aggressive stance of the car
.These pirelli p zero are MO(mercedes approved) or whatever mercedes calls them,and i was assured that these are better than michelin or continental tyres from the dealer.
I can assure you that i never hit a pothole at high speed and always slowed down to idling speed before going over bumps because i know lower profile tyres are much more susceptible to damage.There are no inner wall cracks from where bubble could be formed as i checked it myself during inspection.To me it looks like a poor quality tyre.
Brand new wheels and tyres being installed.
But there are hundreds of "bubbled" tires that have no sign of any kind of mechanical contact with anything, like the OP has it. This can only be bad quality tire, period. The layers of the tire should not separate under any conditions except if something just cuts thru it.
As expected my warranty claim was rejected today.I'll have to buy a new tyre.
Please recommend me some good tyres i'll see if i could sell the remaining three and get some decent rubber.
