Help me choose a used E350
If that is the case it is not as bad as I first thought. Still hate it but maybe not a deal breaker.
I still believe DAG/MB should warrant the ECO start/stop, engine, starter and all affected parts for 10 years or 100,000 miles. If not, they really don't believe it is "The Best or Nothing."
Points to consider
into sales (work at Microsoft) so have to drive a lot.
Live in Dubai - fuel is cheap but would still want something which gives a good milage.
Maintenance cost is the major concern here - both cars out of warranty. Extended warranty available. Should I get it?
What do you all suggest?
Now I do agree there is a delay and jerk in one situation, when you use the "brake hold" feature along with the "stop start". The reason is simply because your foot is off the brake pedal already while stopped and the only signal to restart the car comes when you press the accelerator.
One thing to remember is that the auto stop start does not happen at all stops. It only happens when it meets all criteria including but not limited to engine temperature, battery power, climate control, etc. For example, if the air conditioning is on full blast and outside is scorching hot, the engine may not stop at all.
I understand if some people don't like it though. But remember that the majority of people don't have a problem with it and are silent. The E class is very well insulated from the noises and vibrations.
