Sponsored by: CARiD
Typical oil consumption?
Old Jun 17, 2016 | 08:30 AM
Zavato's Avatar
2012 E350
What are owners seeing as typical oil consumption on the V6 direct injection engine?
Much appreciated
Old Jun 17, 2016 | 09:33 AM
The G Man's Avatar
2019 E300
None.
Old Jun 17, 2016 | 09:37 AM
screw991le's Avatar
2010 E63 AMG
I usually have to add 2 quarts between changes. But we do have different engines.
Old Jun 17, 2016 | 10:44 AM
CarolinaBluetec's Avatar
2008 E320 Bluetec (until 11/14), 2001 SLK 320, 2004 Volvo V70, 1972 MGB, 2013 E350
Little or none.
Old Jun 17, 2016 | 02:45 PM
thenew3's Avatar
2020 X7 xDrive40i, 2016 X3 sDrive28i
I've seen 0 oil consumption over 3 years and 20k miles. I always check the oil level before taking it in for service, and again after getting it back from service. It's always at the full mark.
Oil also stays surprising clean after 7k miles.
I had a previous car that consumed as much as 1qt every 400 miles. (VW/Audi 2.0FSI)
Old Jun 17, 2016 | 04:50 PM
Zavato's Avatar
2012 E350
I asked because now with about 2400 miles since my purchased of a 2012 CPO, I added a bit of oil (Mobil 1 0W40), but admittedly, I never checked the oil level before.
On the other hand, my V6 Honda easily takes a quart of oil every 800-1000 miles. Always has since new.
Thanks all
Old Jun 18, 2016 | 09:33 AM
El Cid's Avatar
Veteran: Army
2010 E350 Luxury Sedan, Engine 272 (V6)
Interesting, on my 2010 I never add oil and only change it annually.
Old Jun 19, 2016 | 01:54 AM
cx876's Avatar
W212, R171
pre-2012 models have different engines, I almost never heard anyone mention that the M272 consume oil
Old Jun 19, 2016 | 01:06 PM
Groganm@live.co's Avatar
E350
I change the engine oil every 5000 miles and never added a drop in 25000 miles
Old Jun 19, 2016 | 04:54 PM
Arrie's Avatar
My oil gets changed every 10000 miles at the dealer service and I change it at every 5000 miles between. I check oil level every time I fill up and so far has not seen any oil loss. My car has 113000 miles on it.
Old Jun 19, 2016 | 06:28 PM
Six_Speed's Avatar
2012 E350 Sedan, 2007 Ford GT500
None here on my 2012 E350.
Old Jun 20, 2016 | 11:48 AM
jahquan3's Avatar
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
We're almost neck and neck since I have roughly 113k on my car as well. During my last Service A, I was advised that I did lose some oil, I'm not exactly sure how much. I was told that I shouldn't be concerned at all.
Old Jun 20, 2016 | 11:05 PM
Arrie's Avatar
My driving is 85 - 90% highway so my engine has only about 40 - 45 kmiles on it comparing to some city drivers. Anyway, oil consumption is a sign of failing piston rings and some posters about the oil consumption have a real issue in their hand...
Old Jun 21, 2016 | 11:31 AM
jahquan3's Avatar
The bulk of my driving is highway as well but I'd say more in the 70% range. They(MB) mentioned there was a leak at the back of the engine housing but it was an insignificant amount. Leading me to believe that a portion of the oil that was lost was burned off so to speak. I don't have another service for about 6k miles. I'll be keeping in eye on it.
I have a friend with an ML63 and he says it burns a bunch of oil and confirmed it was ok to do so with MB since his is under warranty still.
Old Jun 21, 2016 | 11:51 AM
jkwng5's Avatar
2011 E350 4Matic Lux
I drive my 2011 W212 mostly on local roads to and from work and have never a need to add oil...I also change my oil as indicated which is usually on an annual basis.
Old Oct 10, 2016 | 05:28 PM
konigstiger's Avatar
'71 Pinto
See if this helps. Actual pan can be viewed here https://www.avito.ru/belgorod/zapcha...2001_614110090
Old Oct 12, 2016 | 04:25 PM
mikemargolis's Avatar
'11 E350BTC P2 Leather
Mine is a 2011 E-350 Bluetec diesel, the 3.0 OM642 engine.
I have 98,000 miles on it, and am about to do a 700 mile round trip, so I checked the oil yesterday since I am 8000 miles past my last oil change.
ZERO oil consumed.
Gotta like that.
Old Oct 14, 2016 | 09:57 PM
Raymond Lee's Avatar
Lexus LS 400, 2008 BMW 528i, 2014 e250 BlueTec
I have had E350 bluetek and now I have 2014 e250 bluetek but I have never added oil between A and B service.
