Sponsored by: CARiD
Is excessive engine oil that bad for your engine?
Old Jun 20, 2016 | 04:52 AM
juunro's Avatar
2012 E350 sedan
Hi E class & other Mercedes drivers, I just came up with quick question.
I am aware that excessive engine oil is not good for your engine, especially for the crank, pan, valve, etc.
I made a stupid mistake by adding too much engine oil, about a quart.
Right now, my dipstick reads that the oil is slightly above the MAX. I checked it 4-5 times and the oil is reaching above the red plastic indicator about 1 cm, to the string part of the dipstick.
Should I need to top off some excessive oil? or is this amount fine? As of now everything is going well. No noise or rough rpm.
Any advice is highly appreciated! Thanks.
Old Jun 20, 2016 | 08:53 AM
CarolinaBluetec's Avatar
2008 E320 Bluetec (until 11/14), 2001 SLK 320, 2004 Volvo V70, 1972 MGB, 2013 E350
I would get a cheap manual oil siphon from Harbor Freight, etc and take it out.
Old Jun 20, 2016 | 09:03 AM
RA72825's Avatar
Yes. Remove it to be safe.
Old Jun 20, 2016 | 10:19 AM
Speedriven1's Avatar
Speedriven
Yes, it can be. Definitely remove that.
Old Jun 20, 2016 | 11:09 PM
Arrie's Avatar
I would not worry about it but this is just me, I guess...
Old Jun 21, 2016 | 12:45 AM
Peachy's Avatar
2010 E550
If you google this, the general consensus is that your car will probably be ok.
I personally don't know so don't take my word for it.
Old Jun 21, 2016 | 09:55 AM
The G Man's Avatar
2019 E300
My oil level is at the top of the red plastic indicator on the dip stick. If it is 1 CM above, I would drain some of it.
Old Jun 21, 2016 | 04:01 PM
Groganm@live.co's Avatar
E350
The oil level in the pan is intended to be just below the crank shaft journals when the engine is running. When there is too much oil, the spinning journals hit the oil and make the oil frothy with air. The problem is that oil with air lubricates less effectively and you loose a little power pushing the excess oil around with the crankshaft. Being a little low on oil is not harmful but being over can cause problems. Modern oil contain additives to help with froth but they get used up over time.
Old Jun 24, 2016 | 11:02 AM
thenew3's Avatar
2020 X7 xDrive40i, 2016 X3 sDrive28i
I don't know if this is related, but once when I had my VW Passat 3.6 4motion wagon in for service, the dealer over filled the oil, and the very next day I noticed oil all over the engine compartment. Brought it back to the dealer and they said the over filled oil caused oil to leak through the head gasket. So they drained the oil, replaced the head gasket, cleaned up engine compartment (best they could) and refilled to the proper level. I drove that car for another 20k miles without any engine issues and would still be driving it today if it didn't get totaled in an accident.
Old Jun 24, 2016 | 11:29 AM
RA72825's Avatar
Cars come with dipsticks for a reason (and I know M-B eliminated them for a short while).
Those that say overfilling is a non-issue should just keep pouring in oil until it reaches the top of the fill neck like your windshield washer fluid. See how that works for you.
