Distronic: not sure if I have it or not?
- I have a printout of the dealer's orig options list and it says Lane Assist package, Blind Spot Asst, and the like, but does NOT say "Distronic."
- But, on the center speedo module (via the steering wheel menu buttons), I can scroll to menu that refers to "Distance Warning" and "Attention Assist" (where you can set it to "standard" or "sensitive"). Also, I have the wide "stereo-looking thing" that "looks out" the windshield that encompasses the entirety of the rear-view mirror.
So is my system the Passive Lane Assist or the Active "Distronic" one that monitors and actively adjusts my lane position and distance to the car ahead? I'm learning and doing lots of reading where I can find it, but some info I find seems conflicting. TIA, all!
Edward
Edward
I double-checked my manual, and depending on what cameras you're referencing, not exactly: as per my manual, my '14 has two cameras (one flanking either side of the rearview mirror) for the Lane Assist. Apparently it needs that "Stereoscopic" POV to read the lines (manual even says it distinguishes between dotted and solid lines) in order to judge accordingly, to which is sends out that steering-wheel vibration to warn of unintended lane drift/departure (I also verified this on the road ...we got the vibe
). This is the "passive" Lane Assist, whereas the "active" version is bundled with the Distronic feature (and another sensor for determining proximity to the car ahead).From what I gather, this active version is the one that adjusts your CC speed when you are unintentionally closing the distance with the car ahead with CC in use. And, as already mentioned by another astute forumite, there would be a dial to adjust CC speed at the end of the stalk. All these systems talk to one another to do what the Distronic purportedly needs to do.
If I got any of that wrong, someone make it right
Edward
I checked my dash menu options and, of course, no Distronic appears. Though I do have to add that the Lane Assist (less-expensive "passive" one that doesn't brake) can be set to either Standard or Sensitive mode. I wonder what the latter feels like ...only one way of finding out
Edward
Edward
