Sponsored by: CARiD
Spring install, SoCal.
Old Sep 10, 2016 | 10:52 AM
BBB78's Avatar
W212
Can anyone recommend a reputable shop to install H&R springs and alignment.
I am leaning towards TAG Motorsports in Vista, CA, but that is a 140 mile drive from where I live.
Any shops in Riverside County or LA area maybe?
Old Sep 11, 2016 | 01:05 AM
ElisTwoCents's Avatar
2015 E-Class
I know a few guys have had luck with Need For Speed Motorsports in Glendale (about 90 miles from you) in getting their spring/wheels combos done
I would've gone there had I needed springs installed but I lucked out and was happy with the ride height
Old Sep 11, 2016 | 03:22 AM
Uda880's Avatar
2010 E550 Coupe
714 Tires: good prices and speedy service. May be closer to you since they're north of Westminster/HB.
https://www.yelp.com/biz/714-tires-westminster
Old Sep 11, 2016 | 05:18 AM
BBB78's Avatar
W212
I didn't know 714Tires did springs also. They are the most careful people I have ever dealt with when it comes to mounting tires.
Old Sep 11, 2016 | 05:21 AM
BBB78's Avatar
W212
I will check out N4S also, thank you Elis.
Old Sep 11, 2016 | 01:40 PM
Uda880's Avatar
2010 E550 Coupe
Yeah, they do springs and coilover installs with reasonable rates; and afterwards, they can of course do your alignment.
Old Sep 11, 2016 | 02:44 PM
BBB78's Avatar
W212
Do they have a actual car lift? I don't remember ever seeing one there.
Old Sep 11, 2016 | 06:19 PM
2015 E-Class
No problem, easiest would be to give them a call for an estimate. If they are relatively familiar with the work and reputable they shouldn't hesitate to throw a quote your way.
Old Sep 12, 2016 | 09:30 AM
nicobaires's Avatar
13' E550, 14' Ram, 99' E39 wagon
I did mine last week in my driveway, if you are handy, it is really not a hard job at all, the rears are super easy
Old Sep 13, 2016 | 11:23 PM
BBB78's Avatar
W212
714Tire first quoted me at $280 with alignment. They later called me to say it was a misquote because the rear springs required the whole suspension to come out.
Said it would be a 6 hour job. Does this sound right?
Old Sep 14, 2016 | 07:31 AM
nicobaires's Avatar
On mine, I only had to remove one bolt, the one that holds the rear control arm. Remove the bolt, drop the arm low enough to remove spring, reverse it to install. It was the easiest thing to do. Took me, in my driveway about 1.5 hours to do both by myself.
BTW, I was quoted $750 to do all of them.
Old Sep 14, 2016 | 07:36 AM
nicobaires's Avatar
Here are the two bolts circled in red. Just use a jack to lift up in place once you swap out the springs
Old Sep 14, 2016 | 07:50 AM
BBB78's Avatar
W212
Thank you for the photo.
The 13 and 15 model should be identical correct?
Old Sep 14, 2016 | 08:03 AM
nicobaires's Avatar
That I don't know
Old Sep 15, 2016 | 04:27 PM
SoCalC300's Avatar
17 C300 Coupe
European Auto Source in Anaheim installed my H&R springs on my BMW and they really know what they're doing over there. Awesome guys over there! I just spoke with Moe this morning about doing springs on my Coupe. It needs a little something!
https://europeanautosource.com/
Old Sep 15, 2016 | 08:05 PM
BBB78's Avatar
W212
Thank you
