Sponsored by: CARiD
Box on top of battery
Old Nov 14, 2016 | 12:24 PM
El Cid's Avatar
Veteran: Army
2010 E350 Luxury Sedan, Engine 272 (V6)
For first time I took the top off the battery. Apparently it is an air intake box. Is it for the ventilation system?
Why would MB have it above the battery?
When I went to remove it, the clips on either side in back were not hooked on. They set a little higher than the clip posts on the box. Only the middle one was hooked.
Dealer supposedly took it off last year to test it.
When I reinstalled it, made sure all three clips hooked on, but this seemed to make it sit slightly above the battery.
Is this where it is supposed to sit?
MB's sure are complicated. My Toyota's battery is open and clearly labeled as to size, CCA and RC. MB only has the MB logo and part no..
Thanks,
Old Nov 14, 2016 | 12:50 PM
RA72825's Avatar
Yes, it is where cabin air enters, and it does sit above the battery as you indicated. The 3 retaining clips are definitely odd. Be careful not to lose the center one which is a metal clip engaged into a plastic post if I remember correctly. It's like a hat on top of the battery, but should take a total of 5 seconds to remove.
Old Nov 14, 2016 | 04:57 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
I remember the first time putting it back on - had a hard time getting it to sit correctly. If you look on the underside you will see a couple plastic tabs that need to line up with the corresponding notches under the seals around both air openings. When you have it right the cowl/box can almost sit in place due to the tabs and the tension in the seals. Then clamping down the clips just pulls it in tighter. Thanks to all my past AC smell and battery issues, I can do it in my sleep now.
Old Apr 9, 2020 | 11:56 AM
rgtsc01's Avatar
2010 E350 4Matic Sport Sedan
Center clip: I lost mine!
Old Apr 10, 2020 | 07:07 PM
212swe's Avatar
W124 W212
0:34 here you can se how it looks.
Old Apr 10, 2020 | 07:23 PM
Tump43's Avatar
2014 E350 4Matic
What is that box for anyway? Does it somehow keep the cabin fan from pulling in air from the engine bay? or, does it have to do with the battery itself?
Old Dec 25, 2023 | 05:10 PM
ehnazim's Avatar
2010, C250
Thanks,
Can anyone answer this question as i see it is valid and i have same observation?
Old Dec 25, 2023 | 05:11 PM
ehnazim's Avatar
2010, C250
Greate explanation
Thanks,
Old Dec 25, 2023 | 06:15 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
big box
This big air box prevents too much water from entering into HVAC vent.
Make sure it is sitted properly with its bottom hooked secured into car before closing 3 top latches.
It takes a little practice to getting it dropped in centered well.
Take your time.
Old Dec 25, 2023 | 07:19 PM
ehnazim's Avatar
2010, C250
Take your time.
Thanks for quick reply
It makes sense now
My concern is that in Canadian winter it blow/circulate cold air to battery which can drain battery when sitting there.
I remember chrysler use to put bubble jackets to battery which in my observation helps in cold weather.
Thanks And Happy Holidays 😀
Old Dec 25, 2023 | 09:24 PM
It makes sense now
You can use a plug-in battery electric warmer wrapped around it. It's GEL electrolyte not liquid like in the old days.
