Sponsored by: CARiD
Stop/Start not working
Old Nov 25, 2016 | 06:46 PM
mrb999's Avatar
2014 Merc E-350 4 Matic
The stop/start function on my 14 e350 has become less and less engaged since I got the car. Today, the eco button was completely dead. It's off to the dealer on Monday for a fix. Anyone else had similar issues? It generally shows the yellow eco on the dash, but very rarely goes to green. The dead eco button today was a first. I'll let you know what the dealer says, but interested to see if anyone else has had similar problem.
Regards
Dave
Old Nov 25, 2016 | 07:24 PM
PeterUbers's Avatar
Regards
Dave
I had a dead eco button on my 2014 e63S
was an error code from the crank position sensor... they deleted the code and eco worked but they all replaced the CPS just in case and it's been fine
Old Nov 26, 2016 | 12:43 AM
davidjohnbamber's Avatar
2013 E550 Sedan
Auxiliary Battery would be my guess. My E350 rarely had ECO Start work until the battery was replaced.
Old Nov 26, 2016 | 04:27 PM
PatrixUSA's Avatar
2014 E350 W212
+1 ^ on Aux battery as I've had to replace as well, and start/stop does not function when aux battery is dead. Normally it will throw a code but maybe not?
Old Nov 26, 2016 | 10:30 PM
looney100's Avatar
None
Something similar to this happened with the wife's E250. The Eco button light would flash green for a moment when the car first started, but would turn off and couldn't be reengaged
It turned out to be a loose "Eco pump" if I remember correctly.
Old Nov 28, 2016 | 05:48 PM
mrb999's Avatar
Aux battery was fine. They did a software update on the transmission. It does seem to have fixed it, but we shall see.
Old Dec 21, 2016 | 07:01 PM
mrb999's Avatar
2nd visit to the dealer. Stop Start still no worky. Replaced the Aux battery this time. Drove home, still no green light, so looks like another visit is needed. Drove it around today, still no green light. I guess they are cycling through the possible fixes one at a time, starting with the cheapest (software flash). Over and under on getting this one fixed anyone?
Old Dec 24, 2016 | 08:13 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Happened to me on my 14 C350 this morning. At a light, the engine shut down and I had brake hold engaged. About 45 seconds after shut down, the car restarted and it began beeping with the display showing "Brake Immediately". After that, no Eco icon in the cluster and the green light was out.
I've read many times that Brake Hold is dependent on the AUX battery, but it worked for me even with the start/stop system out of commission. After a restart, everything is back to normal. Is the Aux battery covered under the 4/48 warranty?
Old Dec 24, 2016 | 08:15 AM
Allen Yang's Avatar
cls63
[QUOTE = mrb999; 7002026]給經銷商第二訪問。停止啟動仍然沒有worky。這個時候更換電池輔助。開車回家,依然沒有綠燈,所以看起 來就像是需要另一次訪問。今天各地開著它,仍然沒有綠燈。我猜他們是通過可能的修復一次騎自行車,以最便宜 的(軟件Flash)開始。過去,下獲得這個固定的人?[/ QUOTE]
i have same problem ....
