Sponsored by: CARiD
Check coolant warning
Old Dec 13, 2016 | 10:29 AM
sleeperZ96BT's Avatar
2013 E550, 2014 GLK 350
Hi All,
This morning the check coolant level warning came up and went away probably within 1 minute of starting (cold start first thing in the morning, restart after coffee stop did not yield it and no stored warning). I live in MA and the temps have shifted significantly the last week or so (MUCH colder), other than that nothing has changed in the last week with the car.
I will obviously continue to monitor this and check back, but wanted to see where this may lead and if anyone else has experienced this.
Car is a 2013 E550 with ~45k miles.
Thanks in advance!
Brian
Old Dec 13, 2016 | 11:01 AM
belarus27's Avatar
2010 e550 p2
low coolant because of significantly colder tempretures.
might wanna check your fluid and maybe top off a lil
Old Dec 13, 2016 | 11:14 AM
The G Man's Avatar
2019 E300
Silly question, but did you check your coolant level?
Old Dec 14, 2016 | 09:29 AM
Yeah, looked ok and didn't come back after yesterdays message. Wonder if it was simply a sensor hiccup.
Old Dec 14, 2016 | 10:04 AM
belarus27's Avatar
2010 e550 p2
NOPE
later on when it gets cold itll pop up again , itll be here and there untill you add some distilled water or actual coolant , because that means coolant as a minumum level and as it gets colder..............
Old Dec 16, 2016 | 09:09 AM
Yeah, I'm going to check it cold cold cold in the morning tomorrow. If it reads full I will take it to the dealer. It came back on today (3 degrees at 6am) and stuck a bit longer than usual so you may be right.
Old Dec 17, 2016 | 08:14 PM
murray56's Avatar
2011 E350
I too experienced this issue. Coolant level looked good.
After a couple incidents, I added a small amount and problem went away.
Old Dec 18, 2016 | 10:01 PM
550x2's Avatar
2014 S550, 2019 GTC Coupe
Check your windshield washer fluid. The sensors are tied together and low washer fluid can trigger the coolant warning. Really.
Old Dec 19, 2016 | 09:14 AM
Well, I added a small amount this weekend and no warning today, so, I guess even though it was full it needed just that little top off for some reason.
