Rebuilding a 2011 E550; In limp mode help; pic inside
Gorgeous car will be my new project. So the airbags are blown, radiator and condenser are damaged.
Im trying to get the airmatic to work but cant figure it out. States car is in limp mode. Code reader Autel says "compressor is locked - car in limp mode"
I have tried to clear all the codes but car remains in limp mode. Will having blown airbags cause the car to remain in limp mode? Will unplugging the SRS module do the trick?
I will be replacing everything back to oem but want to be able to move the car with the airmatic working vs car being slammed to the ground.
Also, the compressor for the airmatic is located under the driver's side front bumper. It may have been whacked pretty hard looking at that bumper....
I will have to look into a STAR diag unit, I really like this E550 and may keep it as a daily.
Any one have a link or access to WIS download? Im slowly realizing that along with a STAR diag will be the mecca to figure out this car
If you mean how hard will it be to work around using one? It MAY be possible, but time/throwing parts at the car will exceed the cost of a star system...
