Sponsored by: CARiD
Advice on Chirping Blower Motor Replacement (Passenger Footwell)
Old May 2, 2019 | 03:16 PM
jonUF02's Avatar
2015 GL550 4matic
I've heard a very subtle cricket like sound, but I can't figure where it's coming from in the cabin. It does not seem to be dependent on blower speed, this was my first thought, but doesn't seem so. Maybe I'll try the clean just for fun if I get a little free time. Blower motors are generally very simple to remove and replace. For now I just keep the radio up. It also seems to come and go with weather, mostly hearing the noise when weather is colder. Thankfully that's not so often in Florida.
Old May 10, 2019 | 10:02 PM
DeutscheBenz726's Avatar
2019 E 300 4matic 2013 SLK 250
I did mine today (and replaced the cabin filter as well). Used an aftermarket that was cheaper and it took me about 20 minutes to do.
Only problem I had was the zip tie holding the harness to the blower. Bloody old world craftsmen! ROFL!
Old Jan 5, 2020 | 10:34 AM
Zavato's Avatar
2012 E350
I've also started to have a mild chirp from the blower. I hear it when turning right and while braking. It's not that the brake directly causes the chirp, its that the braking causes the car to shift its position or balance, or whatever you want to call it, and there's the chimp. Much like turning right does that too.
At some point- probably spring, I'll replace the blower motor-
Old Jan 5, 2020 | 10:54 AM
TeddyRuxpin's Avatar
W212 E350 CDI Sport
Yeah, mine's come back under certain circumstances after a year and two applications of oil. It also 'whines' at higher RPMs. Just gonna have to get another one, there's a Behr Hella one for £109 in the UK which is OEM, just without the MB markup, so I'll probably get that.
Old Feb 10, 2020 | 02:58 PM
Papaspence's Avatar
E350 4Matic, E400 Coupe, 280 SLK, 500SL
Chirping heater
You do rock indeed! It sounds like it's just the same as it was. In my 09 and that was an easy job. . I'll order the motor and Chase the cricket out of my sedan. :-)!
Old Jun 24, 2020 | 11:32 AM
FrankSemar's Avatar
2010 MB E550 4Matic
Originally Posted by aquinob
Very cool. As these cars get older, more and more folks will be doing repairs like this. Were you able to take any pictures of the process? Steps call for removing glove box and cover on right side of dash as well as pulling the blower. It would be very good for the community that when these fairly simple jobs are done, that pictures of the process are shared.
Note: you only need to remove the glove box if you have a model 204.
Thank you to everyone that added attachments and comments from their own experience.
Old May 13, 2021 | 12:35 PM
  #32
akoustic's Avatar
W212R E63S AMG
Can I ask everyone which aftermarket brand you decided yo replace the original blower motor? Prices range from $80 to $150 from what I can see. Any issues?
Thanks!
Old May 13, 2021 | 12:48 PM
  #33
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Stick with a Behr unit, its OEM. I got mine here: https://www.fcpeuro.com/products/mer...tor-2128200708
Old Jul 4, 2021 | 02:38 PM
  #34
Zavato's Avatar
2012 E350
Did my blower motor too and I also had black dust. That’s the anti-chirp dust which got out of the motor
Old Jul 4, 2021 | 03:01 PM
  #35
Zavato's Avatar
2012 E350
Behr oem
Old May 19, 2022 | 09:03 AM
  #36
NaderA1zain's Avatar
E350 2010, c200 2014
Dont change the part if it is only squeaking
I had this issue and it only needed a clean-up, I followed this video and solved the squeaking issue
Old May 19, 2022 | 09:21 AM
  #37
Papaspence's Avatar
Smile Chirping Blower Motor Replacement
If you're going in there at all, replace the darn motor. It's not real expensive as the other folks have said and there'll never be a need to go in there again. Either you ore the car will die first!!!
Old Feb 21, 2024 | 12:02 PM
  #38
Mass_W212's Avatar
2014 E350 4matic
Good thread. Im having the same issue. 2014 W212 E350. I followed all the instructions in this thread and the other thread on blower motors and it was a pretty easy replacement to DIY. However, now my entire AC system is not working.
I used this part as the replacement: https://www.fcpeuro.com/products/mer...hoC_qYQAvD_BwE
My question is.....Did I just get the wrong part for my car? It was a bit confusing so I used FCP's validator and thats what it recommended. Should I have gotten the same part as konigstiger recommended to OP?
I'm about to reinstall the old unit just to verify I didnt fry anything.
Old Feb 21, 2024 | 01:51 PM
  #39
FrankSemar's Avatar
2010 MB E550 4Matic
Make sure you made all the connections to the fan, it's been a while, but I think there were two or three connections. If the old fan was still partially working it makes sense to install the old motor. BTW, a year after I replaced the fan I had to replace the fan motor speed resister, the fan would only blow at low speed.
Old Feb 21, 2024 | 02:28 PM
  #40
Mass_W212's Avatar
2014 E350 4matic
Good call. I went back to and checked my connections and there was one slightly loose wire plug. Everything is working great now. Thanks for the response
Old Feb 21, 2024 | 02:44 PM
  #41
FrankSemar's Avatar
2010 MB E550 4Matic
I almost felt silly suggesting it, glad it's working for you.
Old Feb 21, 2024 | 03:25 PM
  #42
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
good deal 👍
You divided an conquered... great!
You'll enjoy working on your MB car. These cars are really well built for quick service.
Lots of opportunities to make them run well with couple spares and a helpful collective bunch of friendly members.
