Sponsored by: CARiD
w212 Facelift weak ambitient light system replace?
Old Feb 12, 2017 | 02:11 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
Originally Posted by BlownS4
Beej,
Your steering wheel is on the wrong side of the car!!!!
just kidding man
That looks pretty sick!
you mean the right side. pun intended.
cheers mate!
Old Feb 15, 2017 | 12:03 PM
johnbeal's Avatar
Mercedes E350 Avantgarde Blue Efficiency
Any idea where the ambient lighting bulb can be found. I would like to change mine to blue and also be a little brighter
Old Feb 15, 2017 | 02:47 PM
beejAMG's Avatar
Originally Posted by teksurv
And your gear shift seems to have fallen onto the center console
lol its only a 250 so its a console shift.
ambient lighting is found running through your front dash and behind the door panels. and ambient lighting is an led strip not an individual bulb.
i reckon its a lot of work to change them but ive seen a guy from the C207 or w209 section change/add ambient to their car. ill post a link if i come across it again.
Old Feb 15, 2017 | 08:39 PM
koltonbittner's Avatar
'13 E550 Sedan, '15 S550 Coupe, '15 RR Autobiography
Might be wrong but I believe I read online the led's under the trim are a single bulb with fiber optics and the other lights are strips
Old Feb 15, 2017 | 10:42 PM
Lolxa's Avatar
2010 Mercedes E550 4matic Sport P2, Driver Assistant, Night Vision, Parktronic and Panorama Sunroof
On my 2010 E550, the ambient lighting is a plastic clear tube, if you follow it to the end, there is a single bulb, this is the case for the under the heat vent on the driver side wood trim. I just took the vent to do some vinyl wrapping and saw this configuration. The the side panels on the doors, i can't be sure.
Old Feb 16, 2017 | 06:34 AM
johnbeal's Avatar
Thanks for your reply.It does sound like a lot of work if it is possible
Old Feb 16, 2017 | 10:39 AM
  #32
belarus27's Avatar
2010 e550 p2
yep , wanted to do the same , but it looked like a lot of work , so i gave up for now atleast
