Scraping noise from under car. New cause + solution
I ended up loosening the center support bearing carrier and dropping the tail end of the driveshaft. Using a snap on scope camera and a magnet, I cleared out a large amount of metal flakes and rust debris. The outside of the shaft is not rusted either which is very odd.
Either way, if you have a strange dragging/scraping noise and can't isolate it, perhaps this is your issue. It's easy enough to check (unbolt the rear flex disc, loosen the center support and the shafts can be dropped down).
I dodged a bullet on this one for sure!
**** , i wish i had a lift available at no cost when i need it lol
I just landed shop access but no keys to another friends spot. He has a road force balancer which is going to be damn handy when I mount up my new summer wheels in a week or two when they arrive!
If you are experiencing something similar, her your car on a lift. You can take a stethoscope and put it on the pinion output bearing in each differential, the transfer case outputs and the center bearing carrier as well as the heat shields and back of each brake rotor/wheel bearing. (Car running and in gear). If the shaft isn't rubbing anywhere and nothing seems louder or rough/grinding, it is worth checking out. I literally pulled apart the rear brakes 4 times before finally figuring out that wasn't the issue.
