Sponsored by: CARiD
Threw a rod? Blown engine?
Old Jul 14, 2017 | 08:46 PM
  #126
- Mover -'s Avatar
E550
Originally Posted by i700plus
Just got a call back.. They said I threw two rods. ..
2 rods ? What ? And you were just coasting along ???
I don't mean to sound skeptical, but that really sounds strange.
In my lifetime of driving cars, I have missed a shift here and there badly and have bounced the tach off the rev limiter and the engines were still fine.
It takes a lot to bend a rod. Can you get your old engine back so an indy can confirm what they're saying ?
Old Nov 8, 2020 | 08:02 PM
  #127
mchidiac's Avatar
Saks 5th Ave CL 600
Blown Engine
Was driving my 2010 E550 5.5 V8 car to work this morning and was accelerating normally after a red light. All of a sudden BOOM! I hear a loud bang and what sounds like grinding coming from the front of the engine bay. My check engine light started flashing and the car immediately shut off.
I was able to coast it to a parking spot but after I got out there was a trail of oil/coolant pouring out from under the engine.. Just had my B service done less than 5k ago at a dealership and they said everything was perfect! The car has about 70,000 Miles on it and has had service done at every interval needed. I don't drive the car hard and its performed flawless since I bought it in March of last year with just over 55k on the odometer.
I'm at a loss now what to do. Depending on if its totaled or not and since it wasn't CPO I'm going to be out of pocket at least 8k likely more.. I'll keep everyone updated what the dealership says but I'm not optimistic..
I had the same thing happen with my CL 600.
Old Nov 9, 2020 | 11:27 AM
  #128
Dane500's Avatar
2013 E550 Sedan, 2005 E500 4matic Wagon
Glad everything has worked out. When I was a writer ( at GM) I looked up the cost of a new motor for my 500 wagon. $42900.00 + 22 hrs labor! I'm sure identifix was a bit off but i almost soiled myself. That was for 0 miles OEM.
Old Mar 19, 2021 | 03:37 AM
  #129
Diablo_CLS55's Avatar
2006 CLS55 AMG
Jesus. I know this is an old thread but the only catastrophic failures I’ve heard in the M273 were the early ones having bad timing sprockets causing cam timing go off and eventually Pistons meeting valves. Low key makes me nervous about my E550 with 147k miles... glad you got it fixed though. And if they “couldn’t find” what caused it, especially after they just did a B service, something DOES sound fishy. I think MB corporate should’ve coughed up a new engine for you. Unless you ran the engine completely out of oil, or ran too thick of oil, an engine doesn’t throw a rod or two for no reason. Unless it’s a BMW
Old Mar 21, 2021 | 06:39 AM
  #130
alamry's Avatar
2014, E350 ,4matic, luxury package, AMG kit
Old Mar 21, 2021 | 06:40 AM
  #131
alamry's Avatar
i've been using Castrol-Edge and Liqui-Moly 10w60 thick oils for the past 4 years now on my 2014 mb e350 to cope with the very hot climate country my mb operates in almost year round with temperatures reaching beyond 125F at times, so hopefully she won't be throwing rods any time soon as a result.
