Sponsored by: CARiD
Clanking in left rear over bumps
Old Feb 22, 2017 | 03:04 PM
sdsw's Avatar
2010 E 550
sounds like something is loose. Took to mechanic and was told it was likely the emergency break came loose in the hub and it was not something to worry about though they could take it apart and check it. Is this something anyone has heard of or had experience with?
Oh and long time listener first time caller here. Thanks for any info.
Old Feb 23, 2017 | 11:13 AM
RA72825's Avatar
I cant imagine the ebrake coming loose. Coming loose from what? Try approaching a bump that it normally makes noise at, stop and slightly engage the ebrake and then drive over it and listen. Put up with the red blaring warning that your ebrake is on for a moment. If no noise, then the ebrake is suspect. To see what's going on you need to pull off the rotor, which involves a fair bit of work. Not too difficult if you are familiar with the braking components.
Old Feb 23, 2017 | 11:42 AM
jahquan3's Avatar
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
I've never heard of this either. Seems quite odd.
Oan I love the 1st time caller saying. As I major sports radio listener that is hilarious
Old Feb 23, 2017 | 12:25 PM
belarus27's Avatar
2010 e550 p2
Bushings? Sway links? ....maybe?
Old Feb 23, 2017 | 12:35 PM
sdsw's Avatar
2010 E 550
Thanks for the responses. I will try engaging the break and see what happens.
Old Mar 13, 2017 | 02:00 PM
04E5KHAKEO's Avatar
2010 E550 coupe W212
I have the same problem now on my 2010 E550 Coupe, not sure what is causing it and it rattled when hitting a bump too, I put it on a lift and can't seem to find the problem, everything looks tight.
Old Mar 13, 2017 | 02:26 PM
belarus27's Avatar
2010 e550 p2
check your sway bar related components as well as for bolts make sure they tight(get wrenches and try)...to start with
Old Mar 13, 2017 | 03:28 PM
sdsw's Avatar
2010 E 550
It ended up being the spring that holds the break assembly in place. It has snapped and the banging/knocking was the break. Very quick and easy fix, but did not show on a lift.
Old Mar 13, 2017 | 05:43 PM
RA72825's Avatar
Good to know, so your guy was right all along. Thanks for coming back with the diagnosis. This will help others who may have a similar noise.
Old Mar 14, 2017 | 08:17 PM
MBNUT1's Avatar
2010 E350 4Matic
Love it when people come back and report out the fix. Thanks
