Airmatic without engine running?
I found one post on another form from a W220/S500 where he had to remove 3 fuses from the instrument cluster and the pump started running. I'm looking for a way to possibly do this without using Xentry
http://www.benzworld.org/forums/w220...e-without.html
make sure you find the right Positive and negative terminals , not to burn anything.
but never really checked if i can raise it or lower it with the buttons without starting the car( i mean i did , and it didnt work ) but never tried it with ignition in position 2.
went to check and just like i thought it wouldnt do shi*
pushed the button to 2nd position , and tried switching it to comfort (it was in sport right before i shut the car down) and it woudnt do nothing NOR raise vehicle button worked.
so i guess the car has to be on which isnt an option for i700plus.
My 2010 E550 does not run the compressor if the power is not on. If it did I would not have noticed the leak on the springs when the rear of the car went down after the car was sitting over night or longer. If the compressor was working with power off then the car would have been leveled or the battery would have been dead when the rear was down.
My car makes hissing sound after drive when I stop and get out and close the door. This is because driving pulls the car down so the system puts more air in the springs to keep the level. When driving stops the car raises up and when the engine is shut the car lets air out of the springs to get it back to correct level.
