Sponsored by: CARiD
Earliest build date for 2014 E350
Old Mar 7, 2017 | 01:03 PM
johnlk25's Avatar
2016 E400 4Matic
I was just wondering what the earliest build date would be for a 2014 E350? I just acquired a 2014 E350 with a build date of 9/2013. I thought that was pretty early and was wondering if anyone knew of a build date earlier than that for a 2014.
Old Mar 7, 2017 | 03:26 PM
konigstiger's Avatar
'71 Pinto
These come in @ 3/13:
WDDHF5KB4EA785191
WDDHF5KB7EA780809
Old Mar 7, 2017 | 04:59 PM
johnlk25's Avatar
2016 E400 4Matic
Wow. That early? Thanks for the info!
Old Mar 7, 2017 | 07:58 PM
Tump43's Avatar
2014 E350 4Matic
Mine is 8/13
Old Mar 8, 2017 | 01:19 PM
goober71's Avatar
2014 E350 Sport
I bought a 2014 CPO a few months back. The "in service" date was 7/2013. I assume it was built shortly before that.
G
Old Mar 9, 2017 | 01:24 AM
samkimg's Avatar
2023 XC60 PHEV, 2023 XC40 BEV
I waited for a June 2013 build to get the 360 camera system ...
Old Aug 1, 2022 | 10:27 PM
Looser's Avatar
2009 W211 & 2014 W212 & 2006 F150
I have a 2014 e350 or W212
and I thought I had found the Amplifier after searching for popping electrical burning smell ect.Control Module - Mercedes-Benz
TYP: Sirius – SDAR
HW: 212 870 57 89 Date: 12/2019
SW: 212 902 79 03 Date 12/26/2000
Serial: 063005830376
Mercedes A 212 870 56 89
Model# DL5938
DELPHI Q01
PN: 28335938
Bar Code# A21287056890128335938E1361307
The photo's of the other amps look differant, ware could it be located if not drivers side trunk ? power cable and Fiber connect, Could this be the Amp ?
Old Aug 1, 2022 | 11:04 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
mixed up
I am confused : you're talking about amp frying smell and refering to satellite module ...
I am going to guess you may have audio amp issue, not satellite, right?
Old Aug 1, 2022 | 11:25 PM
Looser's Avatar
Yes Sir, Sorry, i just located the Amp buried deeper in, have to remove the cover to get to it. I believe its the speakers that fry when the amp fails.
Kurt
Old Aug 2, 2022 | 12:14 AM
Looser's Avatar
I would love to repair the amp, has anybody figured out what goes in the amp. or is it sealed in resin and unrepairable. ?
Old Aug 2, 2022 | 12:35 AM
Lottery time...
let's play a lottery game!
We'll try to guess if your amplifier uses available chips or custom chip.
Give us a picture of the amp circuit board and/or the bottom side of your rear shelf.
1- Single amp > no go: Replace ! 😳
2- Woofer amp > 90% chance Repaireable! 😊
Let's see ...
Old Aug 2, 2022 | 12:47 AM
Looser's Avatar
Rear Shelf or package shelf, Just located Amp, Wifes car cant disassemble it yet.
Old Aug 2, 2022 | 01:08 AM
Lucky!
Your pics show separate woofer amp, that means your main amp uses standard SGS-Thompson chips and 16V caps.
Open the main amp at your leasure until then keep it unplugged.
++++++++ READ NEXT POST!! +++++
Old Aug 2, 2022 | 01:21 AM
WASTED FRONT SPEAKER...
if the dual front speaker is cracking, it may be a bad SPEAKER dome and Amp still ok until 16V caps start leaking. Dome can be glued back in 5mn under 2¢
Have a look at the speaker tranducer to see if membrane is falling apart.
It's a dual speaker as originally noted by @Left Coast Geek The second coil is driven by voice from the mBrace module located in the trunk forward floor section. It will log a fault during replacement.
Old Aug 2, 2022 | 01:27 AM
Looser's Avatar
Amplifier A 212-900-62-26
Here is the Amplifier, the trunk was full of ****, not anymore ~~
Old Aug 2, 2022 | 01:32 AM
Looser's Avatar
Have you completed a repair on this amplifier before ?
Old Aug 2, 2022 | 01:37 AM
front spk dome vs. amp. chips + caps
I have not fried mine... because I've reworked it ahead of getting the killer pop-pop-pops 😆
If your issue is limited to center front spk, have a look at it's diaphragm dome for it being loose.
Try to remove only one piece at the time to prevent confusion.
Old Sep 13, 2023 | 04:39 AM
Spruze's Avatar
Mercedes E250 W212 Diesel- OM651
Help me locating my amplifier
I haver mercedes E250 W212 2013 Facelift Sedan. Some speakers are crackling so I wanna check the amp but I cannot locate it in the trunk it’s not there where else can it be? And how many amplifiers in total are there in my car?
Old Sep 13, 2023 | 04:51 PM
main Amp.
Have a look in the trunk area behind the left-side carpet or scan DLC port
