Sponsored by: CARiD
Sound System Question from Newbie
Old Mar 7, 2017 | 01:11 PM
lws1's Avatar
E320CDI, ML350
Just got a 2014 E350. Is it best to load an iPod and connect it to the system instead of messing with a SD disk or CDs or loading the memory? Not sure which way would be the best to accommodate a large library of tunes. Suggestions are appreciated from those of you with more experience on which way to go. Thx!
Old Mar 7, 2017 | 04:31 PM
SteveE400's Avatar
2015 E400 and 2015 GLK350
I'm not sure what you call "large" but I have done just fine using USB memory sticks. I just create a big playlist for the particular trip. I can then fine tune what I take for each trip, and over-write it later.
My biggest frustration in these things is the lousy dynamic range and frequency response necessitated by using the .mp3 file format.
Old Mar 8, 2017 | 01:20 PM
goober71's Avatar
2014 E350 Sport
I love the SD card slot. I've got a high capacity card loaded with a TON of music. Easy to search and play what you need.
G
Old Mar 8, 2017 | 06:30 PM
NSKPhila's Avatar
2018 E300 & 2004 CLK500
I have a sandisc SSD USB drive tucked into the center console (under a tray), filled with 4,000 files (max you can use) of MY music - and it works great. Being SSD, I don't worry about it being bounced around.
leaves the SD slot for those times when the passenger seat isn't empty.
Old Mar 9, 2017 | 12:21 AM
timannnn's Avatar
2014 E350
Is there a certain file structure you guys use to make searching for music easier? Or just load actual mp3 files on root of drive.
Old Mar 9, 2017 | 12:58 AM
SweetJazz's Avatar
2016 E350 Sport
Old Mar 9, 2017 | 10:52 AM
jahquan3's Avatar
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
I don't use the HD or any USB attachments anymore. I just use Tidal and play it through my bluetooth. I'll never be able to collect more music then I can find on a service like Tidal, Spotify, Applemusic etc. Saves me effort and I can create multiple playlist on the fly.
Old Mar 9, 2017 | 11:16 AM
NSKPhila's Avatar
File Structure? -
the CD ripper (dBpoweramp) allows me to set what info I want ripped, I select Title, Artist, and Genre only, dropping track no. This gives me an alpha list of song titles by album
on my SSD, I setup 8 folders, (Classical, Country, Rock, Big Band, New Age... etc). Once a month I'll bring it in from the car and update each folder.
When I plug it back into the console, takes a couple min for the car to read them all, but after that, I just select USB device, then pick the folder I want. You can drop down to the mp3 button and pick Random track, (or even random folder)
That's about all the searching I do
