Sponsored by: CARiD
Driver window all the way up....then down an inch
Old May 18, 2017 | 11:45 PM
scrowley's Avatar
2010 Mercedes E550 4matic
2010 E550. Every time I roll the driver side window all the way up it instantly goes down 1" by itself. Then I roll it up all the way and it stays. Every time.
Any ideas?
Old May 18, 2017 | 11:59 PM
PLINYELDER's Avatar
2023 GLE 450
Reset the window. Roll it up by holding the switch, then when it reaches the top, pull the button all the way up and hold for 5-10 sec, that should reset it if I remember correctly.
Old May 19, 2017 | 09:20 AM
raja777m's Avatar
2014 E350 4M Diamond Silver
Wow, we can reset windows too, lol.
Old May 19, 2017 | 01:40 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
This happens to me at least once a week. I have an OCD habit of starting the car and pulling up on all 4 windows. Sometimes one drops. Most of the time it doesn't.
Hello, my name is thefisch and I have a problem.
Old May 21, 2017 | 12:58 AM
scrowley's Avatar
This procedure did not work.
I also noticed the one touch window up does not work either
Anymore suggestions?
Old May 21, 2017 | 09:18 AM
RA72825's Avatar
Try disconnecting the battery completely for 10-15 minutes, then connect it and follow that reset procedure again.
Old May 21, 2017 | 10:20 AM
scrowley's Avatar
Ok. I'll try that. Will i loose all seat settings, etc?
I'm going to ask a lazy question....new car to me question.
Ha. Where's battery located? .
Old May 21, 2017 | 10:09 PM
PLINYELDER's Avatar
2023 GLE 450
It's a common prob, google it, I may not have given you the correct steps. Easy fix.
Old May 21, 2017 | 10:30 PM
RA72825's Avatar
When you raise the window up DO NOT RELEASE THE SWITCH. Keep holding it for 10 seconds then release.
Old May 21, 2017 | 10:38 PM
thefisch's Avatar
Top Answer: 1
I don't pull the button up all the way at the end. I hold it just below that point for an extra second or two after it reaches the top. I hear a very quiet click and then I let go. I've developed a knack for it so it is second nature now. The first few times I tried it didn't take.
