Sponsored by: CARiD
Question on engine temp
Old May 25, 2017 | 10:45 AM
matman167's Avatar
2017 audi s4
I'm sure somewhere on here there are threads on this but is my temp to high ? Below is a picture of my temp. It's around 90c.
Old May 25, 2017 | 10:48 AM
jahquan3's Avatar
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
Mines is always right over the 80 as well once it's warmed up. I think this is normal behavior. Was yours lower then 80 at any point when warmed up?
Old May 25, 2017 | 12:38 PM
tresean1's Avatar
Veteran: Marine Corps
W212 E-class, W211 E-class, F10 5-Series
Looks about normal...my temp usually hovers in the 3rd-4th 'quarter' of the gauges.
Old May 25, 2017 | 12:40 PM
apg231's Avatar
2019 S450 Silver w/ black interior
Another "same here" just slightly above 80
Funny thing is I never know the temp gauge was in Celsius until I read this post. Sitting in my car now I clearly see the C°
Old May 25, 2017 | 12:45 PM
matman167's Avatar
2017 audi s4
It's never below 80 when it's warmed up and been on the road a bit . It always stays within that picture I posted. It may go up a tad higher but not much more
Old May 25, 2017 | 12:59 PM
RA72825's Avatar
High 80's to 90 centigrade is where mine is parked all of the time. Yours is completely normal. If it should drop to mid 70's and you get a CEL, then your thermostat needs replacing more than likely. It defaults to full open.
Old May 25, 2017 | 01:05 PM
belarus27's Avatar
2010 e550 p2
Between 80 and 90.... i even recorded a video where i was just cruising to work in the Am , and it went from 90 to 80 and stated there for some time.. n then went up again
Old May 25, 2017 | 05:15 PM
PLINYELDER's Avatar
2023 GLE 450
Normal
Old May 25, 2017 | 07:18 PM
Peachy's Avatar
2010 E550
Mine is basically around there most of the time too.
Old May 26, 2017 | 08:54 AM
Ferris_E550's Avatar
MB E550 2010
Normal. I had a similar question few weeks back, and i think Belarus answered it. I did further research and learned that MB gauge temperature is showing the actual engine temperature and that is why it is numbered (40,80,120), unlike Japanese cars (Low, High) . So with MB you can see the temperature ranges between the 82-90C.
Old May 26, 2017 | 09:10 AM
blegthbloo's Avatar
2013 E550 4Matic
Pretty much always at 90*C for me on both of my W212s... even after flexing the 550's gas pedal a bit lol
Old May 26, 2017 | 10:05 AM
belarus27's Avatar
2010 e550 p2
you can actually see it on freeway , how the arrow goes up and down between 80-90C
if you ever pay more attention to it. i even recorded a video , just to have it.
Old May 30, 2017 | 12:06 PM
Milor's Avatar
Mercedes Benz E250 CGI
Recently, I've had the thermostat replaced as the system reported an error code.
I've also noticed some unusual behaviour in the way the engine was warning up. Sometimes it took 2 minutes to get to operating temperature and sometimes it took about 15 minutes. Pay attention to that.
Old May 30, 2017 | 02:53 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Not knowing what engine you have, what is temperature outside and where is your right foot at the moment - you can't say it is normal or not.
Different engines do have different thermostat set and act differently.
My 1999 E300DT would keep 78C when cruising in 102F weather.
Gasoline engines do have higher temp on average, but that again, is engine specific.
Old May 30, 2017 | 07:48 PM
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
Thats pretty good already...
Mine is 100 - 107c lol
