E550 mountain run
The car is completely stock (yes, even using the factory Pirelli tires although they are a little chatty).
I DO NOT use this technique for road courses.
I've seen a few accidents at Tail of the Dragon because of turns like that.
Anyone:
Will my 17s Bridgestone Potenza RE97AS (with 70%+ tread left on it) withstand the pressure or handle the corners well?
I liked the video and subscribed. Keep it up
That was the only reliable and cheaper car during my time, in and around Erie, PA.
other option on my mind is a mini cooper s one of each under $7k, preferably MANUAL(for cooper), to get it out of my system
And mod list:
-13B Turbo engine - rebuilt Jan 2016
-Wolf v500 ecu (complete standalone) and v500 dash unit
-Magnum 60-1 | 65 T4 .68 A/R Turbo w/ billet wheel upgrade
-Greddy Profec B Spec 2 Boost Controller
-Apexi N1 Dual Exhaust
-Blitz 40mm BOV (x2)
-Tial 44mm wastegate
-"V-mount" cooling setup
-Aeromotive 340lph fuel pump
-1200/1600cc injectors
-Cooling Mist Stage 1 Water/Meth Injection Kit (M1 Methanol)
-Lightweight Flywheel
-Competition Clutch Stage 4
-GTUs rear differential with LSD (4.3 final drive)
-Cusco adjustable coilovers
-Front and Rear sway bars
-Mazdatrix rear camber adjustment link
