Replaced rear bags...still dropping overnight
#51
Mine is lower as well. Slammed at the back, slightly lower at the front. Both pass. side.
will see the dealer and let you know if we can figure it out.
#52
Recommended replacing airmatic block. Didn't do anything.
I'm going to guess pass rear height sensor. The weight of the rear being slammed is pulling down on the front suspension. Since the front and rear lines do not intersect anywhere but the airmatic block.
#53
Sounds good. When you bringing it in? Unfortunately when I took mine to the dealer they said the system was working properly with no leaks.
My front left is higher by 12mm, rear right lower by 4mm. When the car is off, rear right is slammed.
I'm going to visit a new service shop.
#54
did you line up a date for service yet?
#55
Hi, yes, the next Monday. My problem might be of a different kind though, I found out the front left spring sits about 1/2" higher than it should. You can see the coil having different position than the right one. Not sure how did it happen and hopefully reassembly will fix it.
#56
Well mine does something different every time.
few days ago it held air for a couple nights but lowered on pass front and rear a bit more.
Last night the rear slammed all way down.
new thing is when the car is locked. I walk up and hit unlock button and open any door or trunk. The airmatic valve block starts making all the electrical noises and the car raises to ride height all around. Without starting it.
Air compressor doesn't run at all when this happens. Even when I start it compressor doesn't turn on. Used to turn on every time. Even after the new block was installed. This has been for about a week with a handful of drives. I'm baffled. Thing has a mind if it's own.
#60
Well thinking about it ... the back drops but now the compressor never runs. It ran every time I started engine before.
I'm assuming the air from rear bags is being pushed back into the air tank resivour. Then I unlock car without starting and it pushes it back to bags.
Def. Not leaking out like before through the blow off on airmatic valve. You could hear it releasing before. Then compressor would run to refill the lost air.
#62
Yesterday I noticed some dropping in the rear of my wagon overnight. Started the car and pulled to the street and checked again and it was at normal height.
This morning, went into the garage and noticed the car once again lower in the rear and passenger side about .25 inch lower than the drivers side.
Thank god for a CPO warranty? My previous X5 was doing this and it wasn't cheap!
#63
so it wasn't my problem.... are you a mercedes tech? Please see my attached video with info I wrote. Lmk what you think
#64
Received 4,435 Likes
'71 Pinto
2010 E550
https://mbworld.org/forums/e-class-w...ml#post7189181
Attached supportive bulletin to dealer’s suggestion, details concerning moisture “may” help. Sorry I do not have referenced jpg files. If you purchased from MB dealer and VIN is within range you “could” have argued for a goodwill claim because rear air springs were modified due to production defect covering entire repair – rear air springs, valve, moisture, etc. If MB revisited not sure how it will play out with Arnott replacements. Next cost effective exploratory DIY step, check compressor air filter. In addition, consider contacting Arnott support.
So mercedes found no leaks or problem in system. They said in this case mercedes recommends replacing the airmatic valve block. This is part right behind rear bumper that has all air lines running to it. They said water in the system causes internals to malfunction. They would not give me a copy of all the work performed at mercedes on my car but let me look through all the details. Car had more flat tires than I've ever seen! Ha. On the other the car has had everything maintained very well up until I purchased I have 28k before any big service.
I just put new Arnott rear bags in. They where installed when I brought it to the dealer too. just started it up and noticed pass side front and rear are noticeably lower. Measured 3/4" difference pass. To driver side. on sport and comfort settings. They have always measured the same.
Well mine does something different every time. few days ago it held air for a couple nights but lowered on pass front and rear a bit more. Last night the rear slammed all way down. new thing is when the car is locked. I walk up and hit unlock button and open any door or trunk. The airmatic valve block starts making all the electrical noises and the car raises to ride height all around. Without starting it. Air compressor doesn't run at all when this happens. Even when I start it compressor doesn't turn on. Used to turn on every time. Even after the new block was installed. This has been for about a week with a handful of drives.
#66
Well I disconnected the battery overnight to rule out an electrical issue....
the car still slammed in rear.
I'm going to try to replace rear air lines.
since I have new bags, new airmatic valve there is not much else to the rear system non electrical wise.
#67
Rear slammed overnight
Hey, I have the same issues. I’m wondering if you ever solved it?
#69
Received 1,736 Likes
1922 Ford Model T / no OBD
I posted it in other threads.
The car doesn't have program who will pinpoint the leak, while technician working with computer want to solve the troubleshooting in couple of minutes, what is not enough to figure out overnight leak.
On my car with such system I installed Tee on air tubing and add pressure gauge on main line.
This way I could observe the pressure build and pressure drop at any time.
Point is that hardest part is to determinate internal or external leak and as above story shows - it can end in nightmare.
Simple gauge will do such determination on couple of checks.
pierrejoliat (09-08-2020)
#70
My E550 looked AMAZING....nice custom mods. sleek black on black BUT with that issue and a handful of others I will never buy another Mercedes unless its sold before 50k miles. Nightmare...
GCWIGGYx7 (06-13-2022)
#71
If you don’t mind me asking, what are some other annoying problems you’ve had? Trying to get an idea of what owning this thing will be like
#72
I came across this thread and I was reading with great interest because I am experiencing the same issue with 2008 Mercedes E550 W211. I was hoping to get to something new I hadn't tried and finally resolve my issue. It ends at the sale of your car. Ugh! Where do I go from here?
#73
If your car is dropping in the rear only overnight, you need to figure what connects both rear air struts to each other and go from there.
If it takes overnight to lose its air, it is a very slow leak, so sometimes soapy water may or may not work. Usually you can find the leak this way.
Most of the time it is in the air line "quick connect" fittings. They are great for manufacturing, but after awhile they become problematic.
I would look at all those quick connect fittings.
My suggestion is to find where both air lines are "connected" and trace back.
Luddyludwick (10-07-2022)
#74
I found this thread through a search (I have a w221). I was having a rear only drop over night in cold weather, last year. During the Summer it was fine. My mechanic said everything was good, might be the rear struts starting to leak. Then it got cold this week and the rear slammed to the ground. When I got underneath I found that the rear height sensor clip had rusted and broken off. I zipped tied it back on the sway bar and the car has been fine for a few days now.
