Correct Brake Pads
My front rotors are drilled and the car is RWD (not 4matic). From what I gather, there are three different brake set ups for E350.
I was planning on buying the Akebono EUR1342 brake pads. Their website doesn't mention anything so just wanted to make sure they would fit my application.
Side note: Will the jack that came with the car be sufficient to use (and place the wheel under the car for added stability/safety)? I've read various forum members' cars being unstable.
Input is appreciated!
Also if you're going to be doing work on your car, you should always get a hydraulic jack, it's much easier and safer with a jack and a set of jack stands. The jack that comes with the car is for emergency use and changing a tire, I wouldn't use it for any automotive work. A standard setup would be to jack the car up, put a jack stand underneath it, drop it slightly so it's resting on both, remove the handle from the hydraulic jack (so you or anyone else don't trip over it) and leave the tire underneath. It's also a good idea not to work alone or to at least be in shouting distance of someone.
