Sponsored by: CARiD
Stock e350 4matic sport 18in offset
Old Jul 21, 2017 | 02:43 PM
BENZINO350's Avatar
2010 Mercedes Benz E350 sport 4matic
im curious what are the specs of the stock 18in rims that come on the sport trim.
i believe they are 32 offset.
I saw a nice pair of rims with 35 offset is it much different ?
Has anyone put 30 offset on ??
what do you guys recommend
30 or 35 offset
Old Jul 21, 2017 | 02:56 PM
RA72825's Avatar
The offset is 48ET front and rear for 4Matic. 30ET would poke out in the front so bad....
35ET up front is the limit as far as I'm concerned unless you cambered the wheel dramatically.
Old Jul 21, 2017 | 03:33 PM
BENZINO350's Avatar
your right I just called mercedes parts department .
what offset do you think I should go with for new rims
Old Jul 21, 2017 | 03:59 PM
RA72825's Avatar
There are too many parameters to just throw out offset specs. Wheel size(18-19) width (8.5,9,9.5). Being sure to Maintain a safe 4Matic setup that won't blow your transfer case, etc. Find some wheels that you are interested in from a vendor on here or other source and make sure they will work for you aesthetically and fit your budget. It's easy to spend $2,500 and way more on new wheels and tires. If you are ready for that, then look around.
Old Jul 21, 2017 | 04:03 PM
BENZINO350's Avatar
im going to get the same set up 18x8.5 all around with 245/40/18 tires
so if the rims I get were 18x8.5 with an offset at 45mm or 35mm will they both fit ?
45 is so close to the stock 48 offset just will close the fender gap a little .
35mm I’m really curious about will that fit nice
Old Jul 21, 2017 | 04:17 PM
RA72825's Avatar
Technically, they should work and others on here are running a 35 Offset with 18" wheels. You are only moving the wheel/tire towards the outside, so you are maybe providing the illusion that the gap is closing. You need to lower the suspension in order to truly close the gap. Does that make sense?
Old Jul 21, 2017 | 04:21 PM
RA72825's Avatar
My car on 19" wheels with a 38ET in front (9" wide wheels) and a whopping 52ET in the rear (9.5" wheels). It is not dropped, but it does give the illusion that the gap is less. It has to do with the wheel size and the fat tires I have on there. I'm not a fan of suspension drops
Old Jul 21, 2017 | 04:22 PM
RA72825's Avatar
Old Jul 22, 2017 | 08:37 PM
kfc2's Avatar
E350 2014 4Matic (AMG Sport pack Bi-Xenon), GLA250 2015 4Matic (AMG Sport Pack Bix-Xenon Distronic)
KEY08,
I really like your rims. Do you have the 4 matic?
I do and I would like to get myself a set of 19". How do you like your set up?
Old Jul 23, 2017 | 09:24 AM
RA72825's Avatar
Thanks. I have 4Matic. The wheels are OEM E63AMG and are a staggered setup. My front tires are 245/35 and the rear are 285/30. There is a .1% circumference difference from front to rear so no issue with the 4Matic. I'm running a high performance summer tire and will put my all season tires/wheels back on in winter.
Old Jul 23, 2017 | 10:26 AM
BENZINO350's Avatar
any rubbing issues with the 38 offset in the front ?
I might do 35 offset in front 8.5 in wide rim
Old Jul 23, 2017 | 05:56 PM
RA72825's Avatar
No rubbing and you should be fine with 35ET and 8.5" width wheel.
Old May 19, 2020 | 06:22 PM
sal1011's Avatar
mercedes e350 sport amg package
2006 mercedes e350 sport amg package wheel problem
Hey guys i have a 2006 mercedes e350 sport with the amg appearance package. I upgraded from the stock 18 inch wheels to 19inch wheels 19/8.5 19/
9.5 i used 235/35/19 tires for the front and 265/30/19 for the rear, but I’m getting rubbing in the rear that I wasn’t even aware of I don’t feel the rubbing at all and it’s eating my tire from the tips on the inside by the inner fender i had to change new tires because of that but I don’t know what to do now whats the solution?
