Help break light leds out ! What do I do?!
In any lighting issue, always check the connector first. You would need to get in behind the trunk liner in the area of that non-working light - there should be a connector in that area. Unplug and plug it a couple times and see if that helps, sometimes a spot of corrosion builds up and does strange things. I just had an issue with back-up camera and this did the trick. If you have or get any dielectric grease, it also helps.
http://www.ebay.com/itm/2010-2011-20...item41c7278524
https://mbworld.org/forums/e-class-w...ngout-led.html
Looks like you'd have to cut the assembly apart to get to the circuit board, then have to figure out if it's led, resistor, or circuit breakdown.
