Heated Seat wiring
I activated the voltage/amp monitoring on the instrument cluster (phone pickup + ok while the ignition is on. see https://snapguide.com/guides/enter-s...cedes-e-class/ )
When activating the passenger heated seat, I could see the amps being drawn.
When doing the same on the drivers seat, the amps would get drawn cyclically meaning it would draw current for a second and then go down for a second and try to redraw the current. This cycling would go on for about 5 - 10 seconds before there would be no current draw at all and the lights would go off in the heated seat button.
Does anyone have a wiring diagram for the seats ?
But you can check this site to see what they have:
http://bbbind.com/free_tsb.html
I'd hate to buy and replace a heating pad and find out later its something else (button, wire, etc) that is causing the problem.
Be careful down there, seat also has an airbag.
the pad itself is about a 100 bucks , and it does look like plug n play , so if you got time and some skills thats doable , unless you wanna pay someone to do it for extra money
you got a leather cover that ripped? Or mb tex
