eco starting in d1
eco starting in d1
2014 e350 4matic still in warranty. 24000 miles. my glk 350 starts out in d2 with eco. the e starts in first every time. eco still shuts engine off. is this normal or should i get dealer to see whats up. thank you.
You mean you start out driving in "C" comfort mode(2nd gear start) and when you stop your car switches to "S"(1st gear start) by itself? If so, I want that function enabled on my car too.
![](https://mbworld.org/forums/images/ranks/veteran_navy.png)
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
My e starts out in 1st gear all the time in C mode. I have the eco turned off but even before I had it turned off it started out in 1st gear. I have never used s mode but next time I drive I will see what it does. Have no idea what GLK 350 does or has.
Received 1,736 Likes
1922 Ford Model T / no OBD
My 2014 E250 starts on 1st all the time as well.
I think with ECO mode you have to use 1st as 2nd on fast restart could jack-rabbit.
Mercedes does lot of designs with no explanation, so we can speculate all we want, but they claim to hire about 60 engineers to fine-tune each car, so they should know something.
My E use to start in 2st gear in C mode. When I got the car, before I left the dealership, sales guy has me done the ECU reset as he was explaining the functions of the car. I had not idea it was ECU reset until I read around in the forum after purchase. Around 500 miles, I start to see it sometime start in 1st gear and sometimes in 2nd. After around 600-700 miles it only start in 1st gear in C mode with or without Eco mode. Maybe the car get use to my driving style. Since I drive short distance, the Eco mode never activate. It seem the battery will only charge after I drive more than 20 miles for Eco mode to be activated after I drove off the freeway into local streets.
The ECO engine stopping at red light needs about 8 parameters to meet and it is hard to figure them all out.
My ECO will stop the engine 1 mile from home, but will keep it running several miles later. I drive in hot weather so I think at certain temperature it will keep the engine on for AC, but then another day it stop the engine with 100F outside.
The AC keeps blowing cold for a minute, although at lower speed.
Lately I discover some dirt on small battery clamps and seem that after cleaning ECO is coming more predictable.
2014 E350, 2020 GLE350
Is it still having the problem with the ECO mode? If you call us, we might be able to help ya out, or at least get you on the right track! +1-888-875-2958
jmow (11-10-2017)
Just bought a 15 E350, ECO worked fine during test drive up until I turned left on our road. About 60 miles from dealer. Hasn’t worked since, not getting ECO in center cluster, any thoughts?
