Sponsored by: CARiD
Vossen wheels - fit?
Old Nov 16, 2017 | 09:46 PM
ccbesq's Avatar
E 550 Cab
Question Vossen wheels - fit?
I’m looking at a set of used 19 inch Vossen wheels for my 2012 E 550 cabriolet. The wheels on the car now are 18 inch AMG‘s. I believe they’re 18x8.5 with a 45mm offset. The Vossen front wheels are 19 x 9 with a 5x114.3 bolt pattern, 32mm offset and 220/40 Michelin tires, and the rears are 19 x 10 with a 38 mm offset and 245/40 tires. Based on what I’ve been able to find here, it looks like they should fit with wobble bolts. Is this correct, and will I need spacers as well? Thanks, Chris
Old Nov 17, 2017 | 07:31 AM
W212fromW211's Avatar
E550 4Matic
You're better off looking for a set that fits. The 212 calls for high offset. I had a set of Rennen wheels with a +42 offset up front and needed a 5mm spacer to clear the front brakes and being lowered I rubbed on every tire from 245/30/20 all the way down to 225/30/20 which is basically no tire. So I swapped out the wheels. And if you aren't lowering it you should be fine with not rubbing, but you will definitely NOT like the way the wheels poke out so much past the fenders. Good luck with your search.
Old Nov 17, 2017 | 07:34 AM
E550 4Matic
Pic for attention.
Old Nov 17, 2017 | 04:38 PM
DanielW415's Avatar
2012 CLS 550
The lug pattern on the w212 is 5x112. The wheels you are considering won't fit without an adapter.
