2011 E550 trans shudder
Thanks for any help.
Totally different cars I know but sounds similar to the shudder many crown vics have. I've rebuilt a number of 4R70w transmissions and have found the majority of them are initially corrected by full synthetic transmission fluid change combined with 10oz Lubeguard additive. Its the only additive I would ever use.
In other cases replacement of the TC solenoid combined with fresh synthetic fluid did the trick. This worked for units with generally lower mileage and reasonable maintenance history. I also made sure I manually removed and cleaned the valve body as that's the only way to remove trapped debris in the passages and valve bores. Fluid flush won't do it.
Taking a correlation to your issue I would suggest transmission fluid change as a first stop. I believe MB fluid is full synthetic. Note that electronic solenoids can also get debris trapped in their inlet screens or in the small bores they fit into. This allows fluid to seep past and can sometimes cause the chattering (shudder) symptoms.
The risk is that you do the fluid change and there is no change. I'm trying to get familiar with these transmissions - if its my own labor I will typically change the solenoid and any other small parts/gaskets while its apart anyway.
Not sure if any of this helps at all, I sort of "out loud" thought my way through possible actions.
Transmission Fluid Kit : $150.91, includes 9 liters fluid, oil pan gasket w/ bolts and drain plug washer, filter w/ valve body seal, TC drain plug w/ seal, and a replacement overflow tube.
: $22.88, allows for connection to the valve body inlet for flushing/filling.
Pyrometer : $19.98, allows for measuring fluid temperature -- I do not have access to the MB data stream so this will have to do.
Sitting at $193.77 for parts and tools. The dealership quoted $700+ dollars w/ labor and did not include the torque converter drain (I have no idea why).
I also plan on dropping down the valve body and checking for solenoids that need cleaned or replaced.
If you're dropping the valve body check if there is a gasket between the vb and case. For the effort of removing it and negligible cost of gasket its better to replace it to ensure no leakage from an old compressed gasket. I always use an in/lb torque wrench anytime I install a vb to ensure no warpage plus I check it against a straight edge upon removal. You'd be surprised sometimes how these aluminum pieces can warp a bit.
I will admit that my approach may be considered overkill but if I'm doing the work I try to replace any minor parts and gaskets encountered. Its easy to do at that time.
Fill Adapter : $22.88, allows for connection to the valve body inlet for flushing/filling.
On the transmission programming note -- is that something I can just go to the dealer and request nicely? Is it normal for them to offer the upgraded TCU flash?
I can post a picture to better explain what I'm about to say, but the slide or rail that guides the manual valve has two quite small plastic tabs towards the end of the maximum travel. One of the tabs snapped off fairly cleanly. I'm not sure how it will affect the transmission -- it seems like it would cause the manual valve to have a little extra play...which may be troublesome. I'd like to epoxy it back together -- does anyone know what type of epoxy is safe/smart to use on something like this? Plastic to plastic adhesion in an oil soaked environment w/ a moderately high heat application.
The TCU flash sounds like a good ideea, I wonder how much they could charge for it if they're not going to do it out of the goodness of their hearts. Good luck with the job, keep us posted!
A picture will help but personally I'm doubtful that an epoxy fix will work long term in that environment. Due to the effort to get back into the unit you may want to think about replacing the piece if possible.
For what its worth I would consider a try it as is. I would be concerned about a glue repair coming loose leaving the broken section drifting around inside the transmission.
I found the stuff here: http://docplayer.net/42124067-722-9-rwd-7-speed-mercedes-c-center-planet-fahrzeugtechnik-hetzel-telefon-002-overhaul-kit.html
I also found it here in english, the part(refference) number seems to be 288741M-1. Site :http://www.cctransmissionparts.com/d...9_Mercedes.pdf and they have a 1-800 number!
