Check Brake Pad Wear message
However, in the two days since the message appeared, it has not reappeared and I've done plenty of driving/braking since then. What's the logic behind this message? I understand there is a wear sensor (one per axle IIRC) and when the contact is triggered you get the message. I thought the message would persist with each trip, but it hasn't reappeared. Could it be a sensor issue or does this warning not nag you like others?
I don't wear pads fast, so did not hesitate to make 3000 miles before actual replacement on older cars, where sensors have been over 2mm before the pad end.
Now W212 suppose has newer system that I did not explore far yet.
The sensors are at 50% pad thickness and computer calculate when it is time to replace- based on your driving habits. That could explain the intermediate warnings.
Don't get me started what I think about software programmers who drive the cars on computers, but not in real life.
But whatever it is, don't ignore the issue for long time.
I have read good things on the forum about Akebono pads and Centric rotors. Those are on my list for the next brake job. Don't care for the shimmy, squeaking and brake dust of OEM.
From what I've seen "somewhere" MB incorporated new feature in those cars.
Now pad sensor is not 2 mm from pad end to trigger instant warning, but it is more like 4-5 mm and when sensor wears, the computer is calculating how much pad you have left base on your driving style.
Sounds exciting, but how much of that is myth?
I confirm that when older cars had sensor touching ground at rotors, W212 do have wire loop that wears open.
Bad part, I usually could reuse older sensors even with some wear, when new sensors are not-reusable when they come to the end. .
Simple estimate.
Backing plate if 6.1mm + adhesive and spike to attach friction material to backing plate assumed as 2mm total 8.1mm as max worn out limit.
So 8.1mm or 1mm of pad friction life from 9.1mm with alarm constantly triggered, that is easy decently driven 3,000 - 4,000KM useable kilometers more to go.
So far, based on my front brake pad consumption, I am getting 3,400 to 4,600 KM per mm consumed.
