Airmatic Malfunction Troubleshooting
I have read that it is common to have a bad wire going to the pressure relief valve. Does anyone have any experience with this? I want to drop the cover from the compressor and look at the wiring, but I am not sure if I can get to it properly without a lift. Do I need a special OBDII scanner to read airmatic codes?
Any help is appreciated.
They are ways to troubleshoot the system without scanner, but they take time and persistence, so IMHO now is good time to invest money in good scanner.
I bought a replacement relay for $10 and that had no effect. My dad sat in the car with me and I turned it on - no airmatic malfunction. I surmised this was because it wasn't trying to lower the car anymore with the added 320lb. I pressed the vehicle raise button and the vehicle began to raise. I pressed it again (to bring it back down) and it immediately brought back the malfunction. I'm 100% convince at this point that the problem is with the pressure relief valve. I am going to take the splash shield off the compressor later today and do some wire continuity checks. I'm betting there is a bad wire going to the PRV causing the "open" code that I've read about. Will report back with findings.
That's a beautiful thing. Congrats on not giving up. Sounds like poor wire routing by Mercedes.
Even US EPC shows different exhaust for my W212 regardless starting with VIN.
How long takes you to stick your head under rear bumper?
lol
