Cabin vibrations after replacement of engines and transmission mounts
Hi all, I own an 2010 E350 4Matic. It is a great car, indeed. I had been having these vibrations due to faulty engine and tranny mounts. I replaced them all in an indy shop, but the vibrations are still there. Let me describe how it is:
the vibration always happen when the engine is cold, idling in D or R, and when coming into a stop. When the engine in warm the vibrations disappear and the car idles and drives smoothly. The vibrations come like intervals, for instance when idling at traffic lights, can you can notice how the vibration builds up and then it goes away. I have the sensation the vibrations comes from the transmission. Anybody can give a hint of what the problem might be?
Thanks!
Thanks!
2010 W212 E550 4matic
Thanks!
Thanks!
Thanks for the quick answer. Sounds like an expensive thing this torque converter. I just come back from running some errands and the car at idle rumble, but after that it was very smooth. I´ll get back to the dealer with these suggestions.
TC is not that expensive, you can get rebuilt items for around 500$online (you have to send your broken one in). I was thinking that your issue might be unrelated to the driving train if it goes away once the engine is warm. It might just be rough cold engine running( or is it just rough idle?) causing the vibrations, which is another novel to explain. If it is that, it should be easy to catch on the diagnostic tool and you can go from there. Keep us posted on what you find.
Hi, I plug today a diagnostic tool and no codes were found. Then I went to auto assistance (they check the cars if something is wrong etc.,) and they couldn't find anything out of usual. They check the serpentine belt, all fine there, as well all the cranks pulleys for play, all fine also. When I got to the shop, the engine had reached its temperature, so they couldn't see the vibrations. Oh, I was expecting to avoid the MB dealership, I see I´ll have no other option. Keep you posted.
Magic4 (01-17-2018)
Hi, this morning when I took the car I noticed that when turning the steering wheel either to right or left I get this groaning noise that adds to the existing vibration.
All this still happens when the car is cold, on a stop and either with engage D or R
Could be the power steering pump, or a low fluid level? I just uploaded a video, hope you can define what this might be.
Thanks a lot
Thanks a lot
Thanks a lot
Thanks a lot
2010 e550 p2
Thanks a lot
Thanks a lot
Thanks for your replies I checked the steering fluid when engine cold, and it was correct, it showed. I guess the fluid expands when engine is warm. The sound quality of the file isn't good, inside the car it is quite trembling. If you listen with headsets at second 9 and after the passing car, you can notice the groaning when turning the steering wheel. Thanks for your support again!
That looks like a really,really bad transmission mount. If the vibrations are worse when idling in D or R then it's the tranny mount. If they are just as bad when in N or P then it's a combination of tranny and engine mounts. Didn't you say you had them replaced? If your car is anywhere close to the vibrations the one in the video has, you should definitely get them replaced asap.
Did you find out what was wrong with yours?
Sounds like you might have a bad torque converter, either improper fluid level or something out of balance on the rotating assembly. Another cause could be a bad harmonic balancer/vibration dampener/crank pulley or a combination of the two. In some cases, a worn out AC compressor clutch could rattle the whole car when it engages and disengages, but you'd be able to see that wobble by visually inspecting it and it shouldn't be determined by engine temperature.
Received 3,336 Likes
MY'14 W212 M276 3.5NA @55kMi
temporarily shaking...
Both banks are running out of balance:
Have a look at the idle long-term fuel trim at operating temp. Do you read a negative lean ?
- clogged upstream lambda
- loose timing tensioners or phaser
- misfires ignition or injection
- non-contributing cylinder
only 42,000 miles :/ E400 coupe tuned & straight piped mufflers
mounts... only decoys
Transmission mount comes into play under torque at speed.
All three mounts can help make things tighter for a while but expect vibrations to keep up -
++++ edit: the above pointer pretty states what the thread title says!
Last edited by CaliBenzDriver; 10-16-2023 at 10:50 PM. Reason: title holds an answer
