First Out of Warranty Repair....$1900. I have questions
2014 E350
2014 E350 59k miles. Several sensors started going crazy a few days ago, car shut down on the freeway. MB dealer couldn't get it in for 17 days! Found a good independent mechanic. All issues tied back to blind spot sensors. $700 a piece not including wiring. Says they were taken out by snow and salt. This wasn't a bad winter! Is this going to be a yearly repair? It looks like MB has had several failures with these but no recall or upgrades? At 1900 per repair should I get the aftermarket warranty?
it seems like the usable life of accessories like blind spot sensors, hands free trunk lift, and etc are about 50K miles....... Just the other day the turbo boot went out for no apparent reason......... my car is just under 50k miles........ hmmmmm. Perhaps extended warranty is not a bad idea.
raja777m (01-25-2018)
2014 E350 station wagon gasoline
This is not good news!
It snowed here heavily last night and I had a bunch of driver assist features go out, including the blind sport assistant, lane departure warning etc.
Everything came back after restart but as this was the second time in about 6 months I am wondering if I should start saving now.
I've got the same car.
Received 1,736 Likes
1922 Ford Model T / no OBD
Would love to see pictures of failed parts.
As far as MB shows - blind spot radars are mounted inside taillight, while lane departure cameras inside central rear view mirror.
How the snow can get into those locations?
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
W212 E-class, W211 E-class, F10 5-Series
Do you mean the sensors stopped working and disabled themselves? Or do you mean the car literally just turned itself off and loss power, leaving you control-less during your trek down the highway?
If it is the former, then this is probably normal, as my advanced sensors in the BMW automatically disable themselves in inclement weather as to not give false warnings and inaccurate control gestures.
2014 E350
When you say "car shut down", what exactly do you mean?
That seems more like a general electrical issue to me (ECU? TCU?), rather than a blind spot monitor (which doesn't have anything to do with control of the vehicle, and doesn't even intervene mechanically; i.e. the car would still function properly if equipped without blind spot sensors) that only flashes a light in the mirrors.
Now if you have said he pointed to the Active Steering Assist or Active Lane Keeping or Distronic sensors then that would have made a little more sense. I would get a second opinion if I were you---seems like that is a bogus diagnosis.
I could be totally wrong, but I (and perhaps a few others in this thread) was thinking you were saying that is was merely the auxiliary safety features that failed...not the entire electrical system.
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/1240x1280/e5502_c04ca34e965f11afe2f4d2061e46be9dfba6d666.jpg)
This is a blind spot/parking assist sensor
The blind spot proximity sensors are mounted in the bumper in the front and rear. They are more robust than the standard Parktronic sensors if you look at them closely. Not sure where you saw they are mounted in the lights. They are subject to weather issues due to their exposure.
Hmm,
So I have the blind spot assist but no parking sensors. Wonder where the actual devices are located? I have had a message that the distronic is unavailable appear in an extreme downpour but I know that relies on a radar system integrated in the front grill. I suspect that if the side rear quarterpanels, (or tail lights), if that is where the sensors are located, were coated with slush and snow they would pull a similar error message. Once the snow and slush are gone, things should be back to normal. I also have no idea why any of these systems would affect the basic drivability of the car. Second opinion for sure. Mine is MY10 out of warranty and no problems.
2014 E350
Wow, so you say the shop said "All issues tied back to blind spot sensors. $700 a piece not including wiring...they were taken out by snow and salt."?
I could be totally wrong, but I (and perhaps a few others in this thread) was thinking you were saying that is was merely the auxiliary safety features that failed...not the entire electrical system.![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
Hmm... It happened again just a day after the snowfall, Tuesday morning, right when I started up the car.
There is no salt here, the snow has stopped and it was a beautiful sunny day. Yet, right after start up the warnings came on.
However it didn't affect drive-ability in any form, as it shouldn't have, just the "nanny" aids packed it in.
However on Wednesday and today (Thursday) everything was / is back to normal so it's might have been just an electrical hick up.
2014 E350
You have to drop the bumpers in order to replace them. For sure on the front two. Not sure if you can access the rear two without dropping the bumper. The attachment clips are all on the inside of the bumper plus they come unpainted.
Norski (02-06-2018)
