Sponsored by: CARiD
LED Headlights
Old Feb 5, 2020 | 03:27 PM
  #126
EuroDriverSD's Avatar
2016 E350 Sport; Mom Wrecked the 2008 E350; sold the 2002 C320
Originally Posted by LILBENZ230
What do you mean by sometimes they dance and sometimes not? Mine do the calibration movement on every start unless, for example, I were to start the car then turn it off then start it back again. In that case it does not do a second calibration.
You saying that yours do not calibrate even after the car has sat overnight? If so something is not right.
Thanks for the explanation. Mine also behave as you described so there's no problem there. I just wasn't sure if they calibrated every single time you start the car (when I turn off the car, then start it up again).
Originally Posted by Red-Town
Got a link to the grille? Want to update mine
I bought mine from a private seller but I have seen many on ebay that look the same - search for W212 diamond grille.
UPDATE
After driving around for a few days and ample opportunity to use the headlights during day and night, I'm happy to report almost everything is working normally. The only remaining issue is the *Active Headlamps Inoperative* message on the cluster and as a result the auto leveling and auto cornering features are currently not working. The tech in Germany is going to take another look at it next week sometime and this weekend I'm going to run my own Xentry diagnostic to see if I can figure it out. I'm confident I'll get it ironed out soon. That said, I'm going to start a new thread with all the DIY info for all those out there looking to do this retrofit. It's going to be a work in progress which I'll be doing in tidbits at a time.
The new DIY thread is here
