auxiliary battery malfunction
After reading a suggesting from a post on this forum see below:
https://mbworld.org/forums/e-class-w...acement-2.html
I will add that the tech said the voltage was a little low and that it wasn't OEM so he would advise next time to get an OEM Aux Battery. So far I've had no issues though. I don't think it's a change right now type of thing so you may have a couple weeks to a month but others might have had a different experience. Good Luck!
I had battery messages in the past, where battery clamp developed some corrosion, or was not torqued properly.
Those things are not easy to test, but lately bought Solar brand battery tester and it is amazing gizmo.
Either way, they both can be recharged. When I got the aux warning, I pulled out the battery and charged with my ctek and it's been fine going on 4 months and colder days since then.
