A3 Service Cost
Welcome to mbworld, and good luck.
Here's my Driveway "A Service"...
$38.64 – Seven Qts, Mobil 1 0-40 (the good stuff) from Walmart
$24.74 – OEM MB 2781800009 Oil Filter Cartridge from MB dealer
$16.08 - Cabin Air Filter from Auto Geek (for the price of one OEM CAF you can buy 3 cheapies and replace them on a whim)
$13.49 – OEM Mann C28004 Engine Air Filter from eEuroparts
$10.00 – DOT4 Brake Fluid (Not really needed until the 4th A Service, if then)
$102.95 - Total
The Dealer wants $1200 for all this? Since they apparently consider their time priceless, ask yourself if your time is any less priceless, (or $1100 priceless)? I find 2-hours of my precious time (in Oct so I don't break a sweat) and roll up my sleeves. Using my topsider oil evac, I don't even need to roll up my sleeves.
It takes me less time -- and far less effort -- to change the oil/filter than it does to hand wash my car.
Mann oil filter less than $10
Pentius air filter each about $5
Two Mann air filters about $17
I've used the Pentius air filters for years on our vehicles and I do oil analysis testing once a year. Zero issues about any contamination.
Oil filter info
https://mbworld.org/forums/e-class-w212/581968-couple-oil-filter-pics.html
But the overall point is that if you want to, you are able to provide good quality maintenance at reasonable cost. Plus it gets you familiar with your own vehicle which is never a bad thing. Since my car is still in ELW there's been some dealer warranty items and I paid for dealer transmission filter/fluid change . That was $325 and worth it to me. My SA knows me and the car and I've never had any problems about doing my own maintenance.
Regardless, dealership charges $250 for A and $550 for B. The B is an A plus replace cabin (combination) filter, brake flush and fluid. For my vehicle both services also include a tire rotation. Dealership always has coupons or specials which reduce the above charges.
Due to low mileage have sometimes delayed services for a year or two - cabin filter for instance. SA agreed.
I own 2 W212`S .
2010 & 2016.
Both are E550 4MATICS
Great cars , Maintenance done by MB dealerships only.
$$$ But trustworthy dealerships.
Not some mechanic learning on my car??
Furthermore, Service Departments don't "fix" or "repair" things anymore. They REPLACE parts only. Back in the day, I used to replace parts to repair pre-electronic ignition distributors. But no more... several years ago, I paid a Ford dealer $600 to "replace" a distributor, because the dealer refused to "work" on it. Sad, because to this day I just know that distributor needed a part replaced that cost no more than $5.
The downside of today's "plug-n-play" tuning is that it also promotes a "plug-n-play" attitude for everything else.
