Sponsored by: CARiD
20" on E550 4Matic - Strut clearance problem
Old May 27, 2018 | 05:25 PM
frc71's Avatar
14' E550
Would like to install a set of AMG 20" wheels (43mm offset vs 48mm stock) with 245-35-20 tires all around on my 2014 E550 4matic. PROBLEM is outside of strut lower spring perch interferes with the wheel. Considering modifying or trimming about 1/4" off of the outside of the front spring lower perch and adding a 15mm spacer to clear the mod-strut. Has anyone trimmed the strut spring lower base/perch or offer another solution? I am not interested in rubber-band tire profiles.
Old May 28, 2018 | 08:25 AM
threeMBs's Avatar
Only MBs - the best or nothing
245/35-20 do not fit upfront on non-airmatic W212 due to spring perch rubbing. Use 235/35-20 (255/30-20 is rubber-band you correctly do not want, but also do fit).
Old Jun 7, 2018 | 09:02 PM
frc71's Avatar
14' E550
thanks
Old Jun 23, 2019 | 04:16 PM
Dou Ble R's Avatar
2011 e550
So you mean 235/35/20 can work on 2011 e550 with 45 et?!?!?
Old Jun 24, 2019 | 02:46 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Look for compatible tire diameter and you're golden. Then any wheel size/offset is just a question of fitting inside the fenders ...
