Replaced engine mounts. Now this...
The next morning I took the car for a test drive and while going down my driveway I noticed the steering wheel is off to the right by about 45 degrees. Not sure why, because the steering shaft and rack only go back together one way. Anyway, as I begin my drive up the street I hear an awful noice in the front end and the car is loosing power. It regains power but now the ECS Inoperative light is on. So my steering wheel is off by 45 degrees and the ECS has an issue.
I read that care must be taken when removing the steering shaft from the rack or possible damage to the clock spring could occur. So with that in mind, I don't believe the steering shaft was rotated while apart.
Here are my symptoms:
1. ESC Inoperative warning on dash;
2 Steering wheel is off center;
3. Cruise Control does not work;
4. Right turn signal does "not" cancel when recovering from a right turn;
5. Left turn signal does cancel when recovering from a left turn;
6. Wipers work;
7. All other functions on the steering wheel appear to work properly.
I am thinking I have a problem with the Steering Angle Column Sensor, but I don't understand what could have gone wrong. Am I on the right path?
Any ideas?
Appreciate your thoughts.
...Dave
PS: Aside from the above issues, the car feels great with the new mounts.
I am still hoping for some input from the forum. Another clue is the "auto hold" feature does not work.
My steering wheel is 90 degrees off center. I was relatively careful not to rotate the wheel while the rack was disconnected from the shaft, but perhaps it moved 90 degrees while apart. When I disconnected the shaft from the rack it appeared it would only go back on one way. I am stumped.
Any ideas out there?
There is an alignment arrow on the plastic sleeve ( I think it's green plastic) that goes into the rack coming from the steering column. You want to make sure that one is centered, pointing downwards. Yours might be off by 90 or 45 degrees. Pop it out again and install it pointing downwards while the wheels are straight and the steering wheel is straight as well( before lifting the vehicle set the wheels straight and once you removed the steering shaft from the rack center the steering - it should feel very light). You might need to recalibrate the steering angle sensor too, but if the only thing you installed differently was the shaft offset by 90 or 45 degrees then you should be fine, popping it back in the right way should be enough.
Take a look here too (especially at #5), it might help you better understand the procedure - https://mbworld.org/forums/e-class-w...-question.html
The green sleeve with the alignment arrow is on the no2 part
I want to follow up on this thread to close it out. I got back under the car, made sure the wheels were straight and noted the steering wheel position was approximately a quarter of a turn off to the right. As noted in previous posts I found, there is a plastic "guide" on the rack that, for the most part, only lets you slide the steering shaft onto the rack one way. So, in order to correct the steering wheel position, I removed the plastic "guide" which allowed me to pretty much slide the steering shaft onto the rack at any position I chose. I slid the two together and check the steering wheel position. I repositioned the steering shaft on to the rack one tooth at a time to get the steering wheel lined up perfectly straight, then tightened the bolt securely. I took the car for a drive and everything functions normally now.
I am still not sure how or why the steering shaft got out of alignment. Perhaps there are splines of some type up in the column that became misaligned when I disturbed the shaft during the removal and replacement of the left side engine mount? Who knows? All I know is my steering wheel is straight, the car tracks straight, everything in the column functions as it should and my car is now smooth as glass at idle.
It was a tough job and I'm glad it's done!
One remark though: are the plastic teeth on the inside of the plastic sleeve worn out or is it just the picture taken at a weird angle? If they are worn, that might explain how the steering became misaligned.
In any event, everything has been working perfectly since I disconnected the shaft from the rack, removed the plastic sleave, straightened the wheels and reattached the shaft.
I would also like to mention again that the new mounts made a huge difference in the way the car feels. I guess the original mounts failed slowly over time (78,000 miles) which is why I really didn't notice the vibration at idle until I read about it in this forum. After I realized what the deal was it drove me crazy until I changed out the mounts.
I had previously replaced the transmission mount when I first started noticing the vibration at idle, but was disappointed it didn't fix the problem. At that point I knew the engine mounts were next. I procrastinated in tackling the job because I thought it would be a little more time consuming than the transmission mount. Boy was I right! But now that all mounts are new I am very happy with the results.
The old mounts were pretty much fully collapsed when compared to the new ones. The car does seem smoother and more balanced around town. Not much difference, if any, at higher speed.
There are 2 engine mounts and one transmission mount. The transmission mount was very easy to swap out. The 2 engine mounts, not so much.
