Replace Belt, Tensioner, and Pulley
https://mbworld.org/forums/e-class-w...-question.html
and
https://mbworld.org/forums/e-class-w...-e350-lux.html
The 2013 E350 (m276) is at 90k and the belt is showing a 'lil cracking. Purchased the contitech belt, tensioner, and pulley just in case. Planning to r&r this weekend.
Can I reuse the tensioner bolts? What is the torque value for the tensioner bolts?
The pulley comes with a bolt. Any special procedure for installing? What is the torque callout for the pulley?
I appreciate your help..
I just order the WIS cds from eBay - they will arrive next week. Thanks
I
https://www.startekinfo.com/parts
For anyone who wants the bolt part number for the tensioner belt pulley (M276 Engine), it is (you need 2):
910143-008002-64
My mom's E350 had a rattle at idle. Inspected it today and it looks like a loose tensioner pulley (not sure if it's possible to be loose or simply a failure). A few questions below (please keep in mind that I'm new to wrenching on Mercedes but I'm a youtube certified mechanic (LOL) on my Toyotas
1) I plan to replace the tensioner pulley along with the 2 guide pulleys and belt. Anything else I should consider while I'm in there?
2) Are OEM parts best value? Pickup at the dealer or are there good online deals?
3) What common tools / sets are needed for basic maintenance on Mercedes? Looks like for this job a set of torx and reverse torx sockets are worthwhile
4) I'll search this as well but any recommendations on "affordable" repair manuals specific to the W212 / M276?
2. dealer only except oil filter was my policy for W166. Most other aftermarket parts can be junk quality especially bearings (pulleys) and electrical parts.
3. metric, torx and e (reverse torx) sockets, and three sizes of click-type torque wrenches
4. $25 or so for WIS on eBay
https://www.ebay.com/itm/185421674259
I came across the linked thread while researching why the torque values are different for the two guide pulleys even though they're the same part. One is 25n-m and the other is 35n-m. Still haven't found the right answer so I just used the different torque values but used a dab of blue loctite and called it good.
Regarding the tensioner match marks, attached is a before and after picture of how they align with an old vs new belt, 2 new guide pulleys, and tensioner.
Hope this helps!
Doing this job is kinda confusing looking at the form it says to torque the guide pulleys to carrier to 70nm then it says Guide pulley carrier/ABC pump to timing case cover/coolant pump to 20nm then is says Guide pulley to coolant pump/oil filter/timing case cover to 35 nm I’m confused on the wording. Can anyone show me a picture or break down on which ones get torqued to what.
Thank you Guys in advance
