Sponsored by: CARiD
Who owns 2010/2011 Mercedes E550
Old Jun 26, 2018 | 11:33 PM
darren gilkey's Avatar
2010 Mercedes E550
I'm just wondering if you guys have had any problembs or what preventitive stuff I could do to keep it running great. I love the car and the 5.5L V8 just want to make sure I keep it maintained I'm around 91k looks like the previous owner kept it up to date on maintaince at a MB dealership at 70k.
Old Jun 27, 2018 | 03:40 AM
bob2011's Avatar
2011 E550
Drivetrain is utterly bullet proof, keep an eye out for the airmatic tho.
Old Jun 27, 2018 | 12:47 PM
Oda112's Avatar
2010 W212 E550 4matic
This is what I've done on mine so far, there are a few things I haven't documented here yet but they'll come soon.
https://mbworld.org/forums/e-class-w...0-gunther.html
https://mbworld.org/forums/e-class-w...-services.html
At you current mileage you need to replace the spark plugs, as per maintenance manual.
Old Jun 27, 2018 | 05:45 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
Since you're at 90k, I expect you did the ATF service and engine air filters at 80k along with A/B service. Plugs should have been done at 60k. Beyond routine maintenance, I've had a headlamp go bad that required the whole assembly to be replaced. And the comand dial stopped turning and the module was replaced.
Old Jun 27, 2018 | 06:51 PM
RA72825's Avatar
Good advice here. They are very stout cars and go like hell. Stay with the regular oil changes and brake flush on schedule. Avoid potholes as best you can or suffer the consequences.
Old Jul 1, 2018 | 11:22 AM
2010 Mercedes E550
Only thing I've done is got a oil change and some fluids filled and flushed. At 86k when I got it I believe the owner kept up with the maintence but none of the 90k maintence has been done.
Old Jul 2, 2018 | 02:23 PM
Lolxa's Avatar
2010 Mercedes E550 4matic Sport P2, Driver Assistant, Night Vision, Parktronic and Panorama Sunroof
I have a 2010 E550 with 151,xxx km which is about 93,xxx miles. So far I haven't had any issues with the car other than the wood trim fading (easy fix by wrapping it in carbon fiber vinyl), I did the oil changes regularly and air filter was changed as soon as I purchased the vehicle (2 years ago). I've taken 3000km trips with zero issues. Though the biggest issue I had was the stinky AC smell which is easily fixed by a foam cleaner (there's tons of threads on this). I also purchased new Michelin Pilot Sport A/W 3+ tires with zero complaints from regular driving (there was some weird tire noise as 190km+, when I was passing a semi). My airmatic doesn't seem to leaking and the suspension still feels good. Though I do have a Canadian E550 which are built a little differently from the US market. If you have anything questions you welcome to ask!
