Sponsored by: CARiD
Turbo waste gate rattle
Old Jul 5, 2018 | 10:32 PM
Robaustin's Avatar
2016 E400, 2015 GLK 350
Hi all - I have a 2016 W212 and on light acceleration between 1800 and 2500 RPM, the turbo waste gates rattle. It sounds a bit like a can full of little stones being shaken. The local dealer tells me this is normal and there is no fix. I don’t think normal means a $73k car should sound like an old truck. Any input form anyone on this issue? Thanks in advance!
Old Jul 6, 2018 | 02:09 AM
bigjule's Avatar
2007 mercedes e63, 2006 bmw 530 Xi with Mtech kit , 2005 ford expedition
Funny because I believe my 15 e400 makes the same noise
Old Jul 6, 2018 | 10:29 AM
RA72825's Avatar
Just tell people who notice that it’s a deisel. I have never heard anything like that in my bi-turbo. Only turbo spool/whine.
Old Jul 6, 2018 | 12:20 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Knowing the engine we are talking about would be very useful?
Than how do you know where the noise is coming from? Not likely you have your head under the hood when accelerating?
Old Jul 6, 2018 | 05:53 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
I think there are other threads on here about the rattle. JMG tracked down the issue at the source but MB still claims it's normal IIRC.
https://mbworld.org/forums/e-class-w...-incl-vid.html
Old Jul 6, 2018 | 08:49 PM
SteveE400's Avatar
2015 E400 and 2015 GLK350
Yeah, my 2015 E400 does it, too. It doesn't bother me that much, as the E400 feels more "mechanical" than my old Lexus LS did. The E400 is a luxury-Performance sedan, and one might expect some noises. The exhaust isn't as quiet as the E350, either. . .
Old Jul 7, 2018 | 11:36 PM
Robaustin's Avatar
It’s the 3 liter dual turbo engine. The dealer diagnosed the rattle as coming from the waste gate linkage. It’s very easy to hear with the window down driving next to a sound wall. There are ways to discern rattles without having one’s head under the hood.
Old Jul 8, 2018 | 01:09 PM
kajtek1's Avatar
Is it gasoline engine?
Must be pretty new design as I did not hear much about it.
Still there are DIY method to quiet rattling rods, like attaching side spring to it, or sliding rubber hose over.
Old Jul 8, 2018 | 02:26 PM
Robaustin's Avatar
Yes, M276 gas engine.
Old Feb 25, 2019 | 01:30 PM
BankRpt's Avatar
E400 Coupe / Infiniti G35X
Hello all,
Any new findings on this topic ?
Old May 14, 2019 | 06:31 AM
drauch86's Avatar
None
Here is the software update they perform. It doesn't make the rattle go away, it just introduces a hiss as well.
Old Nov 23, 2019 | 07:36 AM
BenzWay's Avatar
E400 GLE350 C63
Anyone have an update on the turbo rattle, at 40k miles with the same sound and warranty ending in 5 months. Dealer told me it’s normal as usual
Old Nov 25, 2019 | 02:24 PM
jonUF02's Avatar
2015 GL550 4matic
My E550 with M278 has pretty loud rattle from turbos on cold start, goes away after about 15 seconds. Others have said it's normal, no issues for mine. It's been like that for the last 30K+ miles and 4 years of ownership.
Old Nov 26, 2019 | 11:26 AM
Grant_J's Avatar
'18 E400 Cab
Same noise
I've been to two dealers on the same issue for my 2016 E400. The first dealer did the update and said the noise was normal. I called MB to complain and they said try another dealer and call them back. The second dealer had a much better diagnostic guy and they found the muffler had loose baffles in it. They replaced the muffler and 90% of the noise is gone. Now it only does it between 36 and 42 mph, same as yours under light acceleration especially going uphill. I'm heading back to the dealer to see if this is truly the normal for that turbo or if they can fix the 10%. Will let you know!
-Grant
Old Nov 29, 2019 | 12:14 PM
BenzWay's Avatar
E400 GLE350 C63
I only went to one dealer and they said that these turbos are a state of the art design and their is not fix and this rattle is also on other turbo Mercedes. I’ll check a couple other dealers around here and hopefully a fix comes up or either way the sound doesn’t annoy me it just scares me hearing turbo failures on some other cars
Old Feb 25, 2020 | 12:22 AM
Barbantus's Avatar
I have a 2012 E550 M278 with a Weistec Tune. The car makes 540HP with this tune but the passenger side turbocharger is starting to make this rattling sound at cold startup for the first 15 seconds and now fluttering sound at Wide-Open Throttle. There is a fix that will close the wastegate longer but it will most likely affect my tune as well as your HP numbers. Unfortunately the wastegates are internal on the turbochargers. To top that off the turbochargers are welded directly to the exhaust manifold so in order to permanently fix this issue you will have to replace the entire turbocharge assembly which is around $2000 dealer cost. I have sourced re-manufactured passenger side turbochargers for around $350-450 on eBay most likely with core. But to make matters EVEN WORSE, in order to replace the turbocharger you have to pull the entire engine out of the car. There is no way to sneak the exhaust manifold off of the engine with the turbocharger while the engine is still in the car. It's much too tight of a fit in the engine bay. The wastegate flutter is becoming very noticeable during wide-open throttle now and it's almost embarrassing to see a blacked out Benz on 20" Ace Alloys that makes a loud fluttering ticking noise when passing by. I am most likely looking to pull the engine and replace this turbocharger with a reman this spring/summer and I will post updates once that happens. Anyone with this problem know of an easier fix please let me know.
Old Feb 25, 2020 | 12:59 AM
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
Try to take off C clip off your passenger side turbo and lift up the rod. And make sure you don't turn the rod.
And, make sure you put something underneath waste rod, in case, C clip flies off.
Move the waste gate freely couple times, then, put the rod back with c clip back on.
Wish you luck!!
View this post on Instagram
Old Mar 5, 2020 | 01:18 AM
Barbantus's Avatar
Wish you luck!!
I tried exactly what you said but it didn't seem to make a difference. It sounds very similar to an exhaust leak and it's only from the passenger side. It seems to be less noticeable as the car warms up and the exhaust manifold heats up. But it sounds like a ticking/fluttering at wide open throttle. It has absolutely no affect on performance either just extremely annoying. Not sure what to do at this point. Except get ready for a long weekend or two pulling the motor and sourcing a new turbo. Any other ideas?
Old Mar 5, 2020 | 10:21 AM
jonUF02's Avatar
2015 GL550 4matic
Mine has a fluttering chatter at cold start only. Been like that for the last 40K miles that I have owned it, always did it. Goes away after maybe 15 seconds, I believe its normal / non-issue. If it's not affecting performance in any way, how frequently to you hit WOT where you're hearing the sound? I know I barely ever open mine up. I live and commute on city streets only, top speed limit is 45mph for maybe 1/2 mile, so I basically never floor it, and rarely use Sport mode. Because the power it has is more than I can ever really use, I decided not to get any ECU tune that would compromise the factory engineering and reliability.
Old Mar 5, 2020 | 12:40 PM
BenzWay's Avatar
E400 GLE350 C63
Check muffler, it may have loose baffles which causes rattling
Old Aug 28, 2020 | 01:34 PM
RicoB's Avatar
W205 C300 4Matic
You’re pretty spot on with this and I agree it can be very embarrassing to have this issue on such nice looking cars. I have a 2015 C300 with the single turbo M274 engine and my car has been at the dealer for a couple of weeks now for this problem and numerous times prior to diagnose it correctly. I’ve been hearing the same rattle noise mostly on cold starts and it lasts for about 30 seconds to a minute, but can also hear it when passing close to walls or parked cars. As usual my dealer constantly has trouble hearing or feeling anything I know is an issue and after two or three trips they diagnosed it as some loose heat shields above the transmission. I was baffled at how they could come up with that conclusion since the noise only occurred at full volume during cold starts, plus that heat shield material is very thin. They insulated the shields and somehow claimed to no longer hear the rattle when it’s very obvious. After pinpointing it for them they finally deemed it was the turbo wastegate linkage and said they’d be replacing the entire turbo assembly. I haven’t gotten word yet if the engine needs to be removed but I do know there’s not much space on the passenger side so it’s probably likely. Luckily I’m still under extended warranty. If you start to hear this rattle, it’s not normal and don’t let them tell you it is.
Old Aug 28, 2020 | 02:02 PM
Dane500's Avatar
2013 E550 Sedan, 2005 E500 4matic Wagon
In my experience 3 things can contribute to the rattle. Wastegate actuator rod where it physically attaches to the wastegate arm. The shaft for the wastegate going through the turbine housing and the puck itself against the bypass port of the turbine.
1. Constant back and forth movement can wear away the pintle on the wastegate arm. Then the actuator rod itself can rattle against the actuator arm. This can be shimmed with a thin stainless washer against the c-clip. Move arm after to make sure there is no binding.
2. If the shaft is prematurely worn in the housing, then likely a new turbine or entire turbo is needed. There is no easy fix for that scenario.
3. The puck...couple ways to attack this. If the puck is rattling against the housing then the pre tension on the rod may need to be increased. A half turn on the rod should do it BUT. This can increase / decrease boost (depending on which way you go - shorter= more boost longer = less. A full turn is usually about a half psi. If that does not take care of it, then the puck itself where it is attached to the arm is worn. No easy fix for this. Same as #2 repair. This is not a Mercedes fix. This is just years of playing with turbos.
Keep the shiny side up.
