w212 E200 wont start at 1 try
1 Post
w213 E200 Amg-Line
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Hi!
i drive an mercedes e200 w212 faclift modell year 2014 and the car only have 58000 km on it.
im having some trouble with the car and the dealer cant find the reason or plays dum im realy not sure and these are certified merc delaers.
so my symtoms are when the car is warm, it wont start at the firts try i have to pull the key bak to position 1 and then it starts on the second time,,
and its realy bugging me, becuse i cant find the reason why it is doing that.
when i read the faulty codes i get this code (P220165 code unkown)
does somebody knows about this issue
PLZ HELP
im from sweden so im sorry if the spelling is not correct...
PLZ HELP
1 Post
w213 E200 Amg-Line
does nobody has had this issue. or knows about it?
im realy getting frustrated with this, i had the car back to the dealer but they still cant find nothing wrong with the car….![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
![action](https://mbworld.org/forums/images/smilies/action1.gif)
btw the faulty code was a bad nox sensor witch is replaced,, but the car is still doing that dum thing, when its warm i dosent start at first try (not Always though)
Välkommen,
When you say it won’t start, does it just crank for an extended period and then you stop? It could just be a bad starter. Older cars used to suffer from heat soak to the starter and cause starting problems when the car was warm. Modern cars don’t usually suffer from this, but it’s possible your starter is not functioning properly. Do you have the Eco start/stop as well?
1 Post
w213 E200 Amg-Line
Tack så mycke.
*the car sounds like its going to start for a sec then it shuts down, and some times i can just hold the key on the same position and the car makes another try by its self then it starts.
yes i have start/stop..
but it never does that on start/stop funktion
i have cought this on camera several times doing just that.
so i have send the videos to the dealer, they say they send the videos to Mercedes in germany, but still no answer
thank you 4 replying
Yes, if your Eco function is working every time then something else is wrong. I can’t point you to other posts on here with a similar issue. People have had long cranking periods before start and this was usually a battery problem or the starter was failing. Have you swapped keys to make sure it wasn’t a glitch in the key switch itself? It almost seems like your key is not communicating for a brief moment. If they do find your problem please let us know to help others. I’m a 4th generation Swede in the US 👍
1 Post
w213 E200 Amg-Line
4th gen very cool.
yes i have swaped keys, but it does it with both keys.
and to be honest im too leaning on its something with the keys.
because it seems that with the other key its doing it more often so i have taged the keys with nr and im just now for a couple of days trying out the keys by swaping them each day just to finde out more about that.
but im realy not sure, because no faulty codes are stored in the car. Beside that one faulty code i mentioned earlyer that is fixed and gone.
Today i drove the car and i stoped 4 times at different locations and it started with no problems.
and another thing is when it wont start i have a lot of shaking from the engine.
1 Post
w213 E200 Amg-Line
I just wont to say that i could not figure our what was wrong with the car.. so i sold the damn car to a Mercedes dealer now its there headic...and bought me a new one w213 i just got it.. and ITS SO MUCH BETTER IN EVERY WAY... now i just hope this will last..hehheheh proud owner of the new eclass WOW i say![drive](https://mbworld.org/forums/images/smilies/driving.gif)
![woowoo](https://mbworld.org/forums/images/smilies/woowoo.gif)
Ha!, well that is one way to deal with the problem!! Congrats on the W213 and enjoy it for a long time!
