C300 vs E350
I want to get a used Benz cos I can't afford a new one, so I need your advice.
Which is better to go for in terms of maintenance and reliability 2010 c300 or 2010 e350?
is the parts of 2010 e350 more expensive than 2010 c300?
Owning both a C-Class and an E-Class myself (both made in Sindelfingen, Germany) I am not convinced the build quality or materials used is any different between the two models.
For consumable parts, both use similar oil filter elements, air filters, with similar part prices. Many smaller parts -- like fasteners, etc -- you will find are identical so cost the same.
For major items, the more tech, the more the expense (but not necessarily more depending on the model bought). In other words, 4WD cost more to maintain or repair than 2WD. Airmatic suspension costs more than Standard suspension, pano-roof is more complex to repair than a standard sunroof, etc.
My suggestion is to shop for the features you want, and be happy with it... do NOT plan to turn an otherwise perfect car -- minus a certain feature you really want -- into a horrible money pit by attempting to add that feature aftermarket. Parts bought this way are insanely expensive. Moneywise, you can easily turn an E-Class into an S-Class that way.
If you're in market for 2010 range only, then please add 550 also to your list. I heard it is a pretty fun car to drive and enjoy.
Maintenance costs might not be that different, but the parts might be expensive between them.
I solved both problems by buying a 2012 E550 (in 2017)
Good luck with the search.
From my experience and from what I've read, maintenance and reliability are similar. You won't pay a premium for parts and service on the E versus the C, unless your getting parts and service from the dealership. If you can do some wrenching yourself, and find a good independent shop for the rest, you'll be money ahead.
I use autotrader; if you're close to texas, there is another shop that sells german cars and cars are hot cakes in that website.
My two year old E350 with a V-6 is smoother, quieter........Just sayin
