2014 Water Pump
Post back your success story with a short tutorial for those of us that might face thermostat replacement down the road.
By the way, there are Youtube videos showing removal of the manifold if you have to do it, see here.
Good luck,
Bob
I'll follow up with install info. I need some reasonable temps and it's suppose to be pretty cold here until Thursday.
Installation will have to wait for another day with better temps.
I had gotten my kit from allorings.com but there are other vendors too.
Here's the culprit.
There was a piece of foreign material either on the engine surface or on the gasket at the time of manufacture or the gasket was defective when manufactured. Either way, it should have been caught before it was installed.
1. Disconnect negative battery cable
2. Remove the shields from under the engine and nose of the car.
3. Remove coolant reservoir cap
4. Drain coolant from radiator drain located on the lower driver side facing the fender.
5. Remove serpentine belt
6. Remove air inlet hose attached to the throttle body and air filter housing (there is a sensor and you have to remove the wiring connector).
7. Remove 4 torx screws attaching throttle body to intake. It is not necessary to remove the intake, you just need to massage the throttle body out of the way a smidge.
8. Remove electrical connector on top of t-stat.
8a. Remove radiator hose that is retained by a spring clip.
9. Remove 3 torx bolts that mount t-stat to engine (#27).
10. Remove bolt that holds oil cooler coolant line to t-stat. MB recommends replacing the O-ring. It lists for $12.
11. Move the throttle body slightly and maneuver t-stat out.
Note: If you want to make the job easier, you can remove the oil filter & give yourself more space.
Just do everything in reverse to complete the job.
Last edited by kp1; Dec 3, 2018 at 08:46 PM. Reason: Forgot step to remove radiator hose
