Stuck parking brake on 2016 MB E350
2016 E350
Almost every morning, but especially when it's colder, the parking brake sticks and requires me to put my foot underneath the brake and force it up as I'm pulling the brake release. Is there a fix to this or is this just how it will always be?
Sounds like it needs some adjusting. Of course this isn't normal.
pierrejoliat (04-27-2021)
2016 E350
Thanks. It's just coming up on its A service so I'll have the service dept. take a look. I saw the thread earlier and it looks like it is correctable. We first noticed it when it was still warm outside and my wife couldn't get the 'brake' light to go off, and that was in August/September time frame. It's much worse now. It will start to wear out the tops of my left shoe if this keeps up.
for sure. The e-brake pedal is also very sensitive from my experience. I touch mine by accident when getting in the car on occasion and the warning light illuminates even though it was only nudged by my foot.
Like yours mine sticks when it starts getting 40 degrees or below, I found if you just hold the release lever out for an extended period of time it will eventually and slowly release if you want to avoid pulling it up by foot. Lets say it is 32 degrees out, the initial handle pull will pop it up ~half, if i keep the handle pulled out it will slowly release the rest of the way over the course of 1-2 seconds. Its annoying as hell and considering I am going to Minnesota next week I need to consciously tell myself to not engage the brake to avoid having it frozen solid in the negative temps we will see up there.
I think it is something on the interior side of things though as it works just fine once the interior has been warmed for some time, it will be sticky when it has sat overnight in freezing temps but after driving with a warmed cabin for 15-20 minutes it works perfectly.
But what about minor do-it-yourself guys like myself? Is there any kind of simple fix? Has the dealer described the reason for the problem to any of you who have had it replaced for free? It's more irritating than anything, since my wife's not even allowed to touch the car.
C5 Chevy Corvette, E46 BMW, Honda CBR600RR
Received 1,124 Likes
12 E350 4Matic 13 E350 4Matic AMG Sport
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
Makes you wonder if the new one has a stronger spring or?
Received 4,435 Likes
'71 Pinto
Posted reply in wrong thread, see here: https://mbworld.org/forums/c218/8053...ml#post8324281
Received 4,376 Likes
I thought all W212 still uses the push/pull mechanical cable only.
All W212s use a mechanical, foot-operated e-brake.. correct. These things getting stuck is quite common. Had mine repaired under warranty last year.
Okey, Thanks LIL.
Well, I am not suprised if the push/pull cable will eventually get kinda "stuck" unless we maintain it once in a while.
Rust + dust can't escape easy from the parking brake chamber.
I recently adjusted mine for better bite at foot pedal 4-5 click and clean the chamber.
Nothing stuck though.
ml3504matic____ (04-29-2021)
CaliBenzDriver (04-29-2021)
The following 2 users liked this post by pierrejoliat:
CaliBenzDriver (04-29-2021),
Dennis9850 (09-19-2021)
