2014 E 350 ECO Mode not turning green
I have a 2014 E 350 sport with around 36K miles. Still under the extended MB CPO warranty.
About 3 months ago, I started getting the "auxiliary battery malfunction" message every now and then. i checked with the dealer and they recommended a battery replacement for around $250. I said no thanks.
I found information on here about the replacement auxiliary battery from Autozone. I replaced it last weekend. The switch out was pretty painless, and the battery works fine, but the ECO indicator in the dash will still not turn green. I've been driving pretty long distances over the last few days, but no luck. Weather is in the 50s-60, so that should not be an issue either. The ECO button has the green light on and the HOLD function works fine. Tried toggling the ECO button on and off, but no luck.
Any ideas? Anyone experienced the same issue? Do I need to take it to the dealer?
Thanks.
G
On my 2014 model, I have green block with ECO in it coming on when computer shuts down the engine for short stop.
Noticed that older models have ECO letters showing in yellow/green when system is ready ( I assume) but later models. don't have it.
I had autotell scanner who had ECO function troubleshooting. The display had 12 sensors that needed to become active for function to kick-in. That incluse airmatic, who was excluded on my car.
So final conclusion, when weak battery is most often reason for ECO not engaging, there is much more and without scanner, the glass ball is not very efficient.
Get a scanner !
I can bring it into Autozone and have them check the battery for charge. It does have the same specs as the MB battery, 12V, 200CCA. Supposed to be a drop in replacement.
And the ECO feature i have is the word "ECO" displayed in yellow in the dash, which turns green with a solid border around it when the system is ready to shut down the car upon stopping. Hope that helps.
Any other ideas?
Thanks.
G
Anyway, I did found out that the climate control is part of the parameter for ECO activation. Put it in in Auto with AC on, and the ECO might show up faster.
Since the car starts and runs fine for now, I declined the replacement. I'll go to Autozone and buy a new battery for $199 + tax when i start seeing issues starting the car in the morning.
I've been very UNIMPRESSED by the local dealer here (MB of Sugar Land). I expected a higher level of customer service from MB dealers, but turns out they're just trying to make quick bucks off their customers.
G
Also if you are big fan of MB batteries and have been using dealer service in last 2 years, you can call their roadside assistance and have the battery replaced on your driveway with no labor cost.
G
I'm the member Kajtek mentioned. Thx to another member cetalpha5 I just bought Champion H8 AGM from Pep boys. 4 yr warranty.
Until Jan 27, buy online and get 25% off, plus $40 mail in rebate. Pick up in local store then return old battery for $18 core. Great deal overall.
Battery
G
When I was living in California, I had 8 dealers within 1 hr of driving.
Few years ago key quotes ranged from $180 to $ 440 and anything between. Guess where did I go?
