Engine Dying Out After Warm Start
I've recently ran a star diagnostics on it but nothing came up. Not sure if taking it to stealer is worthwhile since they'll charge me for diagnostics and end up telling me all is fine.
Ive got the exact same issue with my 2013 E350. Intermittently starts then dies just like you described. No CEL. After a few tries will start with rough idle til you give it a little gas. Wondering if you have been able to fix and if so was it the CPS?
thanks!
thanks!
Of course there's no hard and fast rules on repairs but sensors "typically" will store a code as they fail. May not activate CEL but sometimes a permanent or pending fault can be found when looking at vehicle modules and not necessarily in generic OBD data.
Suggest a close visual and hands on wiggle test of engine wiring and connectors and upstream O2 harnesses/connectors. If there's a problem there, it can show up as that random problem you've described.
This can be maddening. Couple years ago I went crazy trying to find random misfire on son's civic. Finally traced it to 2 poor pin connections at the ECU. I don't drink but I seriously considered it at that time.
