Sponsored by: CARiD
Accident - Fixable?
Old Jan 27, 2019 | 11:43 PM
Scarlett Inman's Avatar
E350
Accident - Fixable?
I was in an accident last week in my 2013 E-350. I drove through an intersection looked away a split second to put my cup in the cup holder and saw the break lights of the car in front of me. I went right to miss the car, but swipe him on the rear passenger side, bounced off of him and hit the van in front of him. By the pictures would one say that the car it totaled or could it be saved?? I've yet to hear from my insurance company. Not sure if that is a good or bad thing... Is it just wishful thinking on my part that she can be fixed?? Airbag did not deploy and I have around 97000 miles on the car.. No visible damage inside the car..
Old Jan 28, 2019 | 08:21 AM
RA72825's Avatar
$10-15K. Borderline
Old Jan 28, 2019 | 08:23 AM
hyperion667's Avatar
2012 CLS63
Originally Posted by KEY08
$10-15K. Borderline
I think more......if it's salvageable.
Old Jan 28, 2019 | 11:24 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
If you have LED, single headlight can cost more than car value.
Sad thing, but that is how system work. On more than 7 years old car, small fender bender repair exceeds its value. Especially when you consider California labor.
My son just had similar accident in his Ford Focus. Less than 1 year old car was totaled as its value is $16k.
Old Jan 28, 2019 | 01:16 PM
2011E350's Avatar
2011 E350
I would tend to say TOTALED. Sorry Charlie!!! I would suspect unibody crack at minimum possibly in non visible location. Even if it is salvageable plan anew front end. Left bumper, front,, right, tires, suspension, headlights, hood, latches, grille, radiator, probable core supports and that is just the visible stuff. That doesn't include , labor, prep and paint.
"Gather up your jackets, move it to the exits, I hope you have found a friend"...…...Semi Sonic Closing Time......by Jackets I mean personal items and by move it to the exits I mean ride home. By Friend I mean the Uber driver Spouse, the person that is going to give you a ride home.
Old Jan 28, 2019 | 01:29 PM
ygmn's Avatar
2015 E400 Sedan
I would wait see what insurance says as they are driving the decisions now.
but everything is repairable if your pockets are deep enough.
Old Jan 28, 2019 | 01:37 PM
dbldpr's Avatar
Veteran: Navy
You really would not want to keep it after that much of damage. Hopefully it will be totaled and you can get another one. Sorry to see that happen.
Old Jan 28, 2019 | 02:06 PM
kajtek1's Avatar
If you really like the car and if you are advanced DIY, you can always buy back the wreck from insurance and search JY for same color hood, fender, bumper and whatever you need.
That might take some time, but today you can set alarms to your cellphone when MY wreck comes to JY and be the first one to scope it.
Even if the frame is bent, I remember those cars have bolted front frame extension?
That's a lot of ifs, but doable.
Old Jan 28, 2019 | 02:27 PM
dbldpr's Avatar
Veteran: Navy
Problem is the engine and trans took a bad blow. It may not leak now but I guarantee it will leak soon. That is why I would get rid of it.
Old Jan 28, 2019 | 02:40 PM
Rogue Leader's Avatar
2014 Mercedes Benz E350 Sport 4matic
KBB values that car around $12-$14k pre wreck. Going for you is the bags didn't blow, going against you is its a Mercedes. If the repair cost is over 75-80% of the car's value most Insurance companies will just total it because if something goes wrong after repair they are on the hook for it. Better to clear it from their books ( in a prior life - I worked in insurance for many years).
So in a best case scenario of $14k value meaning if the damage is over $10k its totaled I'd bet you're right there, needs some body parts, header panel, headlights, and some time on the frame machine, no way its below $10k. Its totaled.
Old Jan 28, 2019 | 04:51 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
Probably totalled but the more importantly everyone is ok, right?
Old Jan 29, 2019 | 01:16 PM
cetialpha5's Avatar
LED wasn't until 2014. That's a bixenon headlamp, it has the headlamp washer. The list price for a headlamp is close to 2k, although maybe you can get close to $1500 when buying online and they're a few hundred used on eBay.
Old Jan 31, 2019 | 07:59 AM
mjsbenz's Avatar
2017 E300 4matic Sport
Most likely it will be totaled. 75% rule of cost to fix vs current pre accident value. You have over $20K in damages.
Good news is that you are ok and the car is a hunk of metal which you can replace.
Old Jan 31, 2019 | 03:01 PM
mellonc's Avatar
E250 Diesel
+1
Old Feb 1, 2019 | 08:46 AM
VegasE's Avatar
2012 E350 sedan
Agree. That isn't going to buff out
Old Feb 3, 2019 | 09:32 AM
MBNUT1's Avatar
2010 E350 4Matic
I tend to favor this response. It comes down to if you are willing to do the work yourself and find used parts. If not move on.
