Garage emf interference
I am having the following problem:
1. Car consistently starts in driveway
2. Car consistently starts in garage when parked on outside wall.
3. Car will not fire in garage when parked n inside wall.
4. Car does turnover but it doesn't fire up when parked in the garage bay closes to house.
5. If I push car outside of garage. Car starts immediately.
As weird as this sounds it is exactly what is happening and I can reproduce this.
If you use the key in the ignition in one of the locations (you can yank the keyless go button out to do this), does it work fine, or no start?
Do you have a second car that you can park in the possessed spot and see what happens?
Also we put a Lexus SC 430 there, battery was dead in two days. We keep the sc430 in the spot near outideo walk and it is fine.
Move Alexa to the other side of the living room furthest from the garage?
So...I guess we shouldn't park in lots under electrical transmission lines.
Or maybe inside you leave your phone with bluetooth
DO you lock car in garage and then unlock before getting in to start?
Maybe some type alarm on car does not like key.?
What type of overhead lights in garage have them off.
try garage door open and closed
Any house alarm junk nearby?
DO you have solar panel and inverter nearby?
Find a radio shack (Good Luck) and they have RF receivers to identify what is in the air so you can see if you have any interference.
I was just talking to my mechanic few hours ago on a possible radio frequency interference issue I experienced twice, which was like this :
My car was moving slow, transmission was in D and engine is running (obviously)... and then I heard a mechanical clicking sound for only like 4 seconds.
When it first happen, I could not ID the sound. That was months ago.
2 weeks ago it happened again and my driver was driving it and I was a front passenger, the clicking sound appeared again and my driver identified it as the power door lock mechanism,
but I can't confirm 100% certainty it was the power door lock.... but it does sound mechanically like a power dock lock mechanism trying to engage/lock.
So today ( after I done oil change and flushed brake fluid ), my mechanic told me that what I described, it was most likely a radio interference.
He further explained, many new cars using FOBs will not start if under a cell tower under certain circumstances/ conditions.
Then I came across this post today trying to see if my issue is common and I also googled and found this :
https://forums.tesla.com/forum/forum...l-interference
http://jamaica-gleaner.com/article/a...rt-key-systems
https://www.wardsauto.com/technology...ey-fob-mystery
https://gizmodo.com/mystery-of-block...lve-1832277387
I do not use push button start, I like starting my E400 with its FOB key.
I do not know what frequency is used for Mercedes FOBs key of today, but this information is probably correct, because OEM will follow ITU recommendation for licence free frequency if low power
https://en.wikipedia.org/wiki/Remote_keyless_system
https://en.wikipedia.org/wiki/LPD433 << 433 to 434 Mhz
https://www.enocean.com/fileadmin/re...-buildings.pdf <<< 315 Mhz use
I think these 2 frequencies will be the number 1 suspect in your garage Pete.
Wifi router or similar will be next, but not suspect #1, since 2.4 ghz and 5Ghz is so far away from 315 - 433 Mhz , but they can leak other frequencies too.
This is a 315 & 433 Mhz scanner
Good luck...
