Sponsored by: CARiD
Steering easier to the right than to the left
Old Feb 13, 2019 | 06:18 PM
RealVanCity's Avatar
2012 Mercedes E350 4Matic
Hi all,
I've got a 2012 E350 4matic with about 60,000kms on it. Just noticed recently that the steering is about 2 min out off center to the right. Also, when I'm making right turns, it seems much easier to turn right than to the left. It's assisting more power on the right.
Could this be a alignment issue? or steering rack? Any advice where to start?
Much appreciated,
Old Feb 13, 2019 | 07:12 PM
Mud's Avatar
Mud
2011 E-350 4Matic Sport
Check alignment and at the same time do a close visual inspection of front end suspension and steering components.
Caster setting can impact left/right steering effort and return, but the steering wheel being off center points to possibility something got wacked under there.
Old Feb 14, 2019 | 11:17 AM
bobtuba's Avatar
W212, X254, VS30
Two minutes off centre? As in 1/30th of one degree? How can you even tell?
Old Feb 14, 2019 | 11:24 AM
When I put the wheel level and straight (both paddles level), it starts to veer left slowly while driving. In order to drive straight, i need to have the wheel slightly turned to the right.
Old Feb 14, 2019 | 01:22 PM
belarus27's Avatar
2010 e550 p2
Sounds like alignment issue or a worn out tire
Old Feb 14, 2019 | 04:09 PM
Mud's Avatar
Mud
That's a bit different than your first description. As mentioned before, get the alignment checked.
Old Feb 14, 2019 | 04:11 PM
Oh ok, cool. Thank you! , I'm gonna get her into the shop and find out what's going on. It's really bugging me lol
Old Feb 14, 2019 | 07:47 PM
Mud's Avatar
Mud
Sounds good, please post how it works out. I know having that constant slight pull is pretty annoying. Plus wears tires!
Old Feb 15, 2019 | 06:26 PM
Yup, I totally agree. Will do!, gonna take her in next week and find out what's going on.
Old Feb 20, 2019 | 05:31 PM
So just to update everyone, brought it in to the MB dealer here for an alignment (they had a special on $199 CAD). It's all been corrected to the acceptable German specs. No signs of any other damage or wear to components. There were a handful of settings that needed to be corrected both front and rear axle (including the caster).
The steering feels centered now, and after a right turn it does return quicker. Was just a short drive back from the dealer, but everything seems good. The assist feels both equal now also when turning the steering left and right.
Will keep you posted if anything changes.
I'm much happier now as I like to keep my MB in absolutely tip top shape
Thank you again for your input! Much appreciated.
Old Feb 20, 2019 | 06:38 PM
belarus27's Avatar
2010 e550 p2
What speed would it shake/vibrate ?
Old Feb 20, 2019 | 07:25 PM
There was no shaking or vibrating really. I think maybe past 100km/hr I felt a very small vibration in the wheel prior, however that could have been a front wheel just maybe an ounce off balance.
I was thinking about having my indy shop do it (he was busy and has only 3 bays), and this time around I figured just put it in the hands of the MB dealer for accuracy. Planning on learning a lot more about this beautiful car and maybe doing a few things on my own to save some $ in the future.
